Vinn_scor 6 #1 Posted October 29, 2018 Is it okay to put 85w-140 GL-5 Gear Lube in an 8-speed tranny that calls for 90w-140 GL-5 Gear Lube? It is not much of a difference but I cannot find the 90W and I need to change the fluid soon because it is BAD. Thanks to all those who reply. Share this post Link to post Share on other sites
WHNJ701 4,165 #2 Posted October 29, 2018 it will be just fine 2 Share this post Link to post Share on other sites
953 nut 55,818 #3 Posted October 29, 2018 That will work well in your transmission. 2 Share this post Link to post Share on other sites
roadapples 6,983 #4 Posted October 29, 2018 I think some use 80w90... 2 Share this post Link to post Share on other sites
ebinmaine 68,400 #5 Posted October 30, 2018 1 hour ago, Vinn_scor said: I need to change the fluid soon because it is BAD. . The gear oil that you have should be perfectly fine to use. You say the fluid you have is BAD... that's a very common problem with these because they get left outside and water runs down into the transmission. It would be highly advisable to drain what you can from the transmission (and remember to raise the front of the tractor because there is a bump on the inside of the transmission) and put 2 quarts of diesel fuel in there and drive it around a bit doing a couple figure eights in all eight gears. Do this flush twice then refill with the new oil. Also, double-check the dust boot at the top of the shifter. 6 Share this post Link to post Share on other sites
Vinn_scor 6 #6 Posted October 30, 2018 Thank you everybody! 2 Share this post Link to post Share on other sites
