Series D - Hydraulic Control Valve O-Rings
By
jmack, in Wheel Horse Tractors
Similar Content
By BuffaloD200
Finally getting around to working on my ark loader. The previous owner said he thinks the problem is with the spool valve.
As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
I noticed the power beyond port is connected to the reservoir return. Is that right?
Anyone see anything blatantly incorrect?
By ccs002
Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
By tractorboy79
I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
Images below of cylinders to show similaritys.
By BuffaloD200
'74 D-180
My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
So my thoughts are grab a BFH or sparky the blue tip wrench.
Is there an unpublished step 3.5, or some trick?
