plumb-r
Woodford key
plumb-r
I had to replace a spindle and pulley on my mower deck.I got the parts from A-Z Tractor(great place to deal with). Anyway I forgot to get a Woodruff key. Can someone tell me will a steel key work for it support to be a special shear key material?
JAinVA
You should be fine with correct size key from NAPA,Tractor Supply or other sources.Later decks didn't even have a key in the spindles.
"D"- Man
If you have a Fastenal they may stock them as well
gwest_ca
If this is a greasable spindle you can eliminate the Woodruff key. Click on the picture and download the 2 page bulletin from there.
Garry
