bc.gold 3,403 #1 Posted October 8, 2018 The slide hammer was originally made to remove the front pump from a 44RE automatic transmission that I rebuilt for my 96 Dodge Dakota, everything went well until a large crack in the frame was discovered. The slide hammer has found many uses around the shop, the last job it was used on was to removed the timing gear from an Onan crankshaft and it looks like it will be used to remove the timing gear from a Lister currently being torn down for parts. 4 1 Share this post Link to post Share on other sites
Pullstart 64,388 #2 Posted October 10, 2018 I’ve got one similar that I made in the die shop about 18 years ago. I made all kinds of dowel puller attachments with it, it was a tig welding practice project. One of my go-to tips just happens to replace a vice-grip adjuster screw, so if there’s something the vice grips can grab, I can still slide hammer it out. 1 Share this post Link to post Share on other sites
