jimkemp 527 #26 Posted April 20, 2019 There are a few out there but I haven't heard anything back about them , its hard to find tubing that is 1.450" id , best I can find is 1.525" id and that's not a direct fit to the 300 manifold , so I can build them but the buyer would have to make a some kind of spacer to make them fit on the manifold Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #27 Posted April 20, 2019 11 minutes ago, jimkemp said: There are a few out there but I haven't heard anything back about them , its hard to find tubing that is 1.450" id , best I can find is 1.525" id and that's not a direct fit to the 300 manifold , so I can build them but the buyer would have to make a some kind of spacer to make them fit on the manifold I work for this brand exhaust company, you may try here to get the tubing...https://shop.advanceautoparts.com/p/walker-bendable-straight-tubing-47968/10205481-P ... .060" wall thickness with 1.50" O.D. will give 1.38" I.D. stock and with one these...https://shop.advanceautoparts.com/p/kd-tools-exhaust-and-tail-pipe-expander-1-1-2-to-2-1-2-kdt2071/22988154-P... should get your desired I.D. 1 Share this post Link to post Share on other sites
1995 520H+96+97 937 #28 Posted April 20, 2019 @jimkemp Do you have a 520 muffler for a pattern? Share this post Link to post Share on other sites
jimkemp 527 #29 Posted April 21, 2019 20 hours ago, 1995 520H+96+97 said: @jimkemp Do you have a 520 muffler for a pattern? No , I don't have one , if I did I could make also 1 1 1 Share this post Link to post Share on other sites
EricF 589 #30 Posted April 21, 2019 (edited) Looking back in this thread, count me in for another vote for interest in Onan mufflers for 520's. Well, pretty sure a whole lot of 520 owners will be beating your door down for a good muffler if you have one... "If you build it, they will come!" Edited April 21, 2019 by EricF 2 Share this post Link to post Share on other sites
1995 520H+96+97 937 #31 Posted April 21, 2019 @jimkemp I have a new 520 muffler (have not test fitted). Looks the same as my 1995, 1996 and 1997 520H mufflers. Also have a used (junk) 1988 520 muffler. Heat shield attaches to muffler is different. 2 Share this post Link to post Share on other sites
oneroadkingman 53 #32 Posted April 30, 2019 On 4/21/2019 at 7:07 AM, jimkemp said: No , I don't have one , if I did I could make also I have one that i can donate for the cause if u would like. Share this post Link to post Share on other sites
oneroadkingman 53 #33 Posted April 30, 2019 On 4/21/2019 at 7:08 AM, EricF said: Looking back in this thread, count me in for another vote for interest in Onan mufflers for 520's. Well, pretty sure a whole lot of 520 owners will be beating your door down for a good muffler if you have one... "If you build it, they will come!" count me in also! Share this post Link to post Share on other sites
peter lena 9,074 #34 Posted April 30, 2019 i built one years ago with all stainless steel at work , i only used perforated stainless inside for baffling, was very quiet due to metal wall strength , i might try to recover it for the magnum engine. your work looks good , we as a group would love to have a good muffler source . pete Share this post Link to post Share on other sites
jimkemp 527 #35 Posted May 1, 2019 1 hour ago, oneroadkingman said: I have one that i can donate for the cause if u would like. If you want to send one to me I will try to reproduce it and send you the first one for free , I will pm you my address 2 2 Share this post Link to post Share on other sites
rk1953 4 #36 Posted August 27, 2019 On 4/30/2019 at 9:16 PM, jimkemp said: If you want to send one to me I will try to reproduce it and send you the first one for free , I will pm you my address have you tried the new 520 muffler yet ? Share this post Link to post Share on other sites
jimkemp 527 #37 Posted August 27, 2019 19 hours ago, rk1953 said: have you tried the new 520 muffler yet ? I cant find a die for the tubing bender that will make the bends tight enough , to have a custom die built would be way too costly for me to do , the radius is 1 3/4" , most dies are 3 1/2 to 4" Share this post Link to post Share on other sites
lynnmor 7,552 #38 Posted August 28, 2019 3 hours ago, jimkemp said: I cant find a die for the tubing bender that will make the bends tight enough , to have a custom die built would be way too costly for me to do , the radius is 1 3/4" , most dies are 3 1/2 to 4" Can you come up with a print of exactly what you need? I may be able to help. Share this post Link to post Share on other sites
jimkemp 527 #39 Posted August 31, 2019 On 8/27/2019 at 9:56 PM, lynnmor said: Can you come up with a print of exactly what you need? I may be able to help. I really don't have a print of the die , but it has to be for 1 1/8" tubing with a 1 3/4" radius that can bend 90 degrees , the tubing bender I have is a woodward fab manual bender Share this post Link to post Share on other sites
lynnmor 7,552 #40 Posted August 31, 2019 (edited) So you need this with a much smaller radius? I didn't really expect formal prints, just a sketch that shows dimensions and mounting holes. Perhaps you could trace around your smallest tooling and then show the reduced numbers. A few photos might help. I do think this will be a tough bend job with that small radius. I have a tool & die shop and am pretty much retired, my interest in this project is only to help members and possibly get stainless mufflers. I do have a spent muffler for a pattern if you need it. Edited August 31, 2019 by lynnmor 1 Share this post Link to post Share on other sites
J Rankin 0 #41 Posted September 4, 2019 I am searching for a replacement for the Nelson muffler on my two C-195s. I have an old rusted out one you could use for a prototype if you are interest Share this post Link to post Share on other sites
WHX?? 50,615 #42 Posted September 4, 2019 (edited) I have one of you muffs Jim so just using this thread to tell you yours seems to accumulate condensation when it sits. Its not a huge problem. It quickly goes away after a minute or less of run time. One just has to learn to lean to the left on a cold start to avoid a face full of it. It does sometimes deposit little black soot spots on the hood but washes away. More so of course with cooler weather conditions. I don't know if others experience this. Other than that yours are great and I will be ordering another in the future. I just love the sound tho so I'll take a little soot for the team! Edited September 4, 2019 by WHX24 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #43 Posted September 4, 2019 On 8/31/2019 at 9:44 AM, jimkemp said: I really don't have a print of the die , but it has to be for 1 1/8" tubing with a 1 3/4" radius that can bend 90 degrees , the tubing bender I have is a woodward fab manual bender What about a "conduit" bender? ...https://bisedwardsironworkers.com/td90-1-125x3-edwards-tube-die-1-1-8-x-3-90.html?gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaclLNGb9d_1CmPlfqLYTqzK6PQ7fIB3ydSY0Nd7nojDBaNN4K5fssaAnUtEALw_wcB Share this post Link to post Share on other sites
jimkemp 527 #44 Posted September 5, 2019 On 9/4/2019 at 11:39 AM, WHX24 said: I have one of you muffs Jim so just using this thread to tell you yours seems to accumulate condensation when it sits. Its not a huge problem. It quickly goes away after a minute or less of run time. One just has to learn to lean to the left on a cold start to avoid a face full of it. It does sometimes deposit little black soot spots on the hood but washes away. More so of course with cooler weather conditions. I don't know if others experience this. Other than that yours are great and I will be ordering another in the future. I just love the sound tho so I'll take a little soot for the team! I'm glad you like it , I know I made the mistake of my C120 got caught out in the rain and the pipe was pointed the right way for the rain to go right in , after the rain storm I went out to get the tractor back in the barn and when I fired it up I got covered in black , wet soot , not sure what to do about condensation in the muffler , I haven't heard any one else say anything about that , I don't think I can put a hole in the bottom as that would let exhaust out , Sorry if its getting the hood dirty , maybe I can send a free cleaning towel with every muffler for cleaning the hoods off only kidding !!! 1 2 Share this post Link to post Share on other sites
jimkemp 527 #45 Posted September 5, 2019 On 9/4/2019 at 4:23 PM, WVHillbilly520H said: What about a "conduit" bender? ...https://bisedwardsironworkers.com/td90-1-125x3-edwards-tube-die-1-1-8-x-3-90.html?gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaclLNGb9d_1CmPlfqLYTqzK6PQ7fIB3ydSY0Nd7nojDBaNN4K5fssaAnUtEALw_wcB The problem is that those benders are 1 1/8 x 3 , the "3" stands for 3" radius , that's way to big Share this post Link to post Share on other sites
jimkemp 527 #46 Posted September 5, 2019 On 8/31/2019 at 2:47 PM, lynnmor said: So you need this with a much smaller radius? I didn't really expect formal prints, just a sketch that shows dimensions and mounting holes. Perhaps you could trace around your smallest tooling and then show the reduced numbers. A few photos might help. I do think this will be a tough bend job with that small radius. I have a tool & die shop and am pretty much retired, my interest in this project is only to help members and possibly get stainless mufflers. I do have a spent muffler for a pattern if you need it. The problem with making I die that small is the tube bender I have ( woodward fab ) wont except any smaller die , a whole tube bender would have to be made , a die , a follower die and a way to pull the die around to pull the tube through , the only way I see it happening is to buy weld elbows and piece the pipes together , only ones I can find 1 1/8 are stainless steel ,and there not cheap, stainless can be welded to mild steel to make the rest of the tube , but all the time it will take to do that plus build the muffler buy the flanges , I don't have one of these motors to build it on so now I would have to build a fixture off of another muffler , that all takes time that I wish I had but since I drive a tractor trailer and haul propane and winter is getting close , my time in the shop gets less and less , So if you can come up with a way to bend the tubing and make the tube part I would be interested in buying the tubes to build the rest of the muffler , And just so you know to build an all stainless muffler you would be in the $400 range , stainless aint cheap Share this post Link to post Share on other sites
Pullstart 64,432 #47 Posted September 6, 2019 Could you post a picture of what you’re trying to duplicate Jim? Maybe somebody here has an idea to build them? @Achto... Share this post Link to post Share on other sites
lynnmor 7,552 #48 Posted September 6, 2019 2 minutes ago, pullstart said: Could you post a picture of what you’re trying to duplicate Jim? Maybe somebody here has an idea to build them? @Achto... Post #31, and others, have a photo. I have been doing a bit of research to come up with a way to reliably bend those pipes in stainless steel. Those sharp bends are smaller than any engineering standard would recommend. I could make tooling, but if the tubing will not accept the radius, it is all for nothing. I'm not saying it is impossible, just a challenge to develop tooling and a procedure. 1 Share this post Link to post Share on other sites
Pullstart 64,432 #49 Posted September 6, 2019 10 hours ago, lynnmor said: Post #31, and others, have a photo. I have been doing a bit of research to come up with a way to reliably bend those pipes in stainless steel. Those sharp bends are smaller than any engineering standard would recommend. I could make tooling, but if the tubing will not accept the radius, it is all for nothing. I'm not saying it is impossible, just a challenge to develop tooling and a procedure. Gotcha, they are the header pipes? Rookie comment from someone with no Onans in the shed... Share this post Link to post Share on other sites
jimkemp 527 #50 Posted September 7, 2019 On 9/5/2019 at 8:29 PM, lynnmor said: Post #31, and others, have a photo. I have been doing a bit of research to come up with a way to reliably bend those pipes in stainless steel. Those sharp bends are smaller than any engineering standard would recommend. I could make tooling, but if the tubing will not accept the radius, it is all for nothing. I'm not saying it is impossible, just a challenge to develop tooling and a procedure. The tubing will accept the radius , its just the tooling ( die ) has to hold the shape , they are made in the factory with a rotory bender , where the die rotates and pulls the tubing into the die , the die is deep enough so the tube is more than 1/2 way in , in other words if you want to bend a piece of tube 1" od the die has to be at least 5/8" deep so the wall of the tube cant flex outward , todays benders the die are 1/2 the depth of the tube , 1/2" deep for 1" tube , it can be done , its just not cheap to do for someone like me with a small welding shop its way above what I could ever afford to buy 1 Share this post Link to post Share on other sites
