plumb-r 34 #1 Posted October 4, 2018 I have a 42" rear discharge deck that the pulley are through the spindles on. Problem is the model # on the deck is blank. The tag is there just no numbers. I guess wore off. I would like to buy a whole new spool piece. Cup ,bearings,spindle shaft,ect. I can then take my time and rebuild the old one and keep as a spare. Any idea of another way to ID model of deck? The tractor is a 1980 C145A. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted October 4, 2018 Rear discharge mower deck should be one of these models Mower DNA 1976 model 65-42MR01 replaced by - (Has the flat spindle belt idler pulley mounted on a triangular plate.) 1977 model 75-42MR01 - Both use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. (Has the flat spindle belt idler pulley mounted on a triangular plate.) ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These use blades with 3/4" center hole 1977 model 75-42MR02 replaced by 1978 model 85-42MR01 1979 model 95-42MR01 1979 model 95-42MR02 1980-1983 model 05-42MR01 1984 model 05-42MR02 1985 model 05-42MR03 1986-1988 model 05-42MR04 1989-1990 model 15-42RC01 1990-1992 model 15-42RC02 1993-2012 model 78350 These charts show what spindle assemblies were available for each deck. Click on a line in the index and it will take you to a single page showing all available over the years for that deck. The first illustration was the original design. Garry Share this post Link to post Share on other sites
