Anglo Traction
Clutch Idler Shaft Mod
Anglo Traction
Ok yes I'm lazy for not dismantling the relevant parts and properly repairing the shaft, but realised that the very small bearing surface on the R/H end of the shaft where it passes through the Frame needs enlarging. Also, I had problems trying to remove the Spirol Pin on the left Brake rod Arm(6-10) -
So I chose the easy way out, plus increased the shaft bearing surface at the wear point by about 600% and in 3 planes (fwds,up and down).
Found the perfect bearing which is about 1.1/2" long, 3 sides square and 1 side open. Hard cast brass with exactly 1/2" internal dims, so the shaft fits perfectly inside it.
Cut a 1/4" 90 deg angled plate down, spotted through the spare hole in the frame nearest the Transmission and tapped the hole 5/16" x 18 (SAE/UNC) in the plate.
Bonded the bearing to the plate by tapping,screwing and soldering.
Fixed in place after packing with grease-
Bolt position through the Frame, seen through the Gear slelector gate-
Nice and smooth now, only noise is the usual 'Belt Slap' on the inside of the cover.
Edited by Anglo Traction
  • Like 4
