bo dawg
How does the D series snow plow hook up?
bo dawg
May sound stupid but since I'm new to the big D's, does anyone have a picture or diagram of how exactly the snow plow hooks up on the mid lift? It has the spring loaded rod too. Its a bit different looking then the C's and I want to make sure I do it right.
Thanks
WVHillbilly520H
Thanks
@Sarge, think you can help Bo out here?
  • Thanks 1
gwest_ca
 Click on the fuzzy picture
DNA
1973 model 6-1131 (54") replaced by
1974 model 6-1141 (56")
1975 model 6-1142 (56")
1976 model 66-56BA01
1977 model 76-56BA01
1978 model 86-56BA01
1979 model 96-56BA01
1980-1982 model 06-56BA01
Garry
  • Excellent 1
Sarge
The spring-loaded lift link comes into the blade's frame from the left side, washer and hairpin clip on both top and bottom studs. I can try to get a picture, later on, a bit dark out there right now...
That link is adjustable, read up on it in the instructions. It does work well to allow some down pressure while allowing some float - that blade is so heavy it cuts quite well.
Sarge
bo dawg
DNA
Garry
Thanks Garry, this is exactly what I needed. I was searching on here in the Manual section but couldn't come up with it.
I installed it yesterday to what seemed correct, but according to this I have the spring assy up side down and in the wrong hole on lift bar. Lol!
I was afraid of the long end of the assy lift rod sticking up into the tractor and hitting somewhere, so I thought it pointed down.
Glad I see this now.
bo dawg
Sarge
Thanks Sarge, after looking at the post Garry added I can see clearly now. Wow now I have that song in my head...… I can see clearly now the rain is gone...…. Lol
Sarge
One real important tip - unless you want an immeasurable amount of misery, watch what you're doing with that plow. One good, hard shock load against that pump coupling and it may blow the splines out, which results in a lot of money/time/aggravation.
Sarge
