Hoosier Hydro 520 3 #1 Posted September 26, 2018 I recently purchased a 1987 312-A...Model 21-12KE03...so far I love this little tractor (besides the backfire when shutting down).My question is concerning Hydrostatic transmission fluid requirements and service.. I have read 2 different wheel horse manuals..1 says SAE30w, the other SAE20w. Both manuals say no service interval..Does any one know correct weight of oil to use?? And it would seem to me to be prudent to replace with new oil as I don't know history on tractor?? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,337 #2 Posted September 26, 2018 Have heard here 10w 30 is the way to go. 1 Share this post Link to post Share on other sites
roadapples 6,983 #3 Posted September 26, 2018 (edited) Should be 10w30... Crib types faster than me.... Edited September 26, 2018 by roadapples 1 Share this post Link to post Share on other sites
OHRob72 88 #4 Posted September 26, 2018 Try low throttle for about 10-15 seconds before shutting down and see if this stops the backfire. My dad's C165 would backfire if I shut it down without letting it run at low idle.for a few seconds. Worked for me but others might have a better fix to this. 2 Share this post Link to post Share on other sites
oliver2-44 9,871 #5 Posted September 26, 2018 My C160 also backfires if I shutdown at some throttle I take it to idle like mentioned above and no backfire 1 Share this post Link to post Share on other sites
520hC-120 136 #6 Posted September 26, 2018 to Used 10w30 in my 520h tranny. Has worked great! 1 Share this post Link to post Share on other sites
953 nut 55,821 #7 Posted September 26, 2018 (edited) 2 hours ago, Hoosier Hydro 520 said: recently purchased a 1987 312-A. Your 312-A should have a Eaton 700 automatic transmission (no oil filter). If that is the case then there are two oil levels to be looked at. Take a look at page 16 of this manual (page 12 of the PDF). The Eaton 700 is not serviceable, just add oils. Edited September 26, 2018 by 953 nut Share this post Link to post Share on other sites
Hoosier Hydro 520 3 #8 Posted September 26, 2018 Thanks 953..so Reading the pdf...SAE20w for Hydrostatic transmission fluid with 3/4 of a quart capacity..and no service interval.. This pump has no drain plug so would have to draw out oil from plastic resovoir on top..or would you just leave it alone?? I have no idea when this oil has been replaced if ever... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #9 Posted September 26, 2018 Garry Share this post Link to post Share on other sites
953 nut 55,821 #10 Posted September 26, 2018 If your transmission is performing properly I would leave well enough alone. This manual covers your Eaton. I do not own an Eaton 700 and posted to correct the incorrect information posted by others. There are several threads on here covering the 700 for further information. Share this post Link to post Share on other sites
pfrederi 17,885 #11 Posted September 26, 2018 Newer engines have an anti backfire device. Issue was the exhaust system is hot ..carbon build up etc. When you shut her off the engine turns over several times sucking in fuel mixture no spark to ignite it it gets blown out to the muffler build up and hot spot ignites it, newcarbs have a solenoid that shuts off the fuel when the switch is turned off. Let her idle down..cools off exhaust system and the engine turns over fewer time after shut off pumps less unburned gas into muffler. 1 Share this post Link to post Share on other sites
shallowwatersailor 3,213 #12 Posted September 27, 2018 1 hour ago, Hoosier Hydro 520 said: Thanks 953..so Reading the pdf...SAE20w for Hydrostatic transmission fluid with 3/4 of a quart capacity..and no service interval.. This pump has no drain plug so would have to draw out oil from plastic resovoir on top..or would you just leave it alone?? I have no idea when this oil has been replaced if ever... You could use a turkey baster to draw it off. There actually is a drain plug on the transmission but difficult to find. The transaxle has its own oil sump with a drain plug underneath. It should be a 1/4" allen head plug.The transaxle uses 10W-30 motor oil. With regards to the backfire, each time it does backfire it affects the muffler. It will eventually split. On the Kohler 5xi tractors, a shutdown procedure to prevent backfires was to allow it to idle down and then give it full throttle while turning the ignition off. Share this post Link to post Share on other sites
Hoosier Hydro 520 3 #13 Posted September 27, 2018 I don't think this eaton pump has a drain.. the transaxle does..1/4" plug..I have already changed that.It takes 10w30.but the hydro reservoir is separate on this unit.. I may take your advice 953..sometimes leaving well enough alone is best..I just hate to leave that pump oil in there not knowing how nasty it is..Maybe that turkey baster idea.. as for the backfire,,,I tried it all...low idle,,fast idle,,mid idle,, changed plug, seafoam,,marvel mystery oil, now back to standard gas. It made no difference..still sounds like a deer rifle when I shut it off 1 Share this post Link to post Share on other sites
shallowwatersailor 3,213 #14 Posted September 27, 2018 13 minutes ago, Hoosier Hydro 520 said: I don't think this eaton pump has a drain. See the drawing on page 7. http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1616.pdf Share this post Link to post Share on other sites
953 nut 55,821 #15 Posted September 27, 2018 50 minutes ago, Hoosier Hydro 520 said: backfire,,,I tried it all...low idle,,fast idle,,mid idle,, changed plug, seafoam,,marvel mystery oil, now back to standard gas. It made no difference..still sounds like a deer rifle when I shut it off If you engage the PTO momentarily to load the engine (presuming there is a mower or snow blower hooked to it) the load will stop that. Share this post Link to post Share on other sites
