Similar Content
By lsc1257
I have a 1996 520H Wheel Horse for sale. The tractor has just over 800 hours on it. It comes with a 48 inch deck. The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago. This 520-H has the swept front axle so it can handle a 60 inch deck. I just replaced the battery and the deck belt this summer. The engine is a 20HP Onan and it starts right up but requires the full choke. The transmission is an Eaton 1100-062, hydrostatic. The deck is in rough shape but the spindles appear to be in good working order. The right rear tire has some cracking. The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck. Also included is a new PTO belt and several miscellaneous deck wheels and rollers. Additional pictures available upon request. Asking $500.
By Joe Warren
Wheel Horse
Service Tool Kit
Onan Industrial Engines
ON-420-0556
Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
$129 plus shipping cost.
Message me if you are interested in purchasing. Thank you. Joe
By carlejoyce
Just installed new starter, new carb, replaced valve guides. lapped ad adjusted the valves. Engine is running like a top but when load is applied I experience a power loss to the point the engine will stall. Any ideas to solve problem???
By SPINJIM
1992, Wheel Horse 520-H. Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts. Seat is like new. Front tires are new. All tires hold air. Some repainting, but didn't need much; was stored indoors. New decals. Other new parts.
Has swept front axle and Variable Ratio Steering. Belt cover ventilated to cool back cylinder. Rear wheel weights are 55 lbs. each.
By odee61
Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan? My PTO disc went today. Any help would be most appreciated.
