Countdown To Christmas!
Realwhiteboy
Axle id
Realwhiteboy
I have a 8 speed axle,3 speed with reverse and high and low option. It has what looks like a 8 to 10 inch pulley with a tapered shaft. Also has disc brake and tge high and low shifter is at the back of the axle. Anyone know which one this would be?
The Tuul Crib
 Welcome to red square! Not  sure what you have what you need, but pictures will help bunches somebody should be a long that can help as well!  Welcome to the addiction !
pfrederi
What is the diameter of the axle shaft itself...1" or 1-1/8"
stevasaurus
Like Paul said...axle diameter and a picture of the left and right side of the trans.  See if there are any numbers & letters up by the shifter...casting date.  :)
gwest_ca
Sounds like a Foote transmission
Garry
Realwhiteboy
Not sure size of axle shafts at the moment  has 5x4.5 hubs an 12 inch wheels. The pulley is vertical instead of on top.
stevasaurus
post a picture...it will make it easy to ID then.  All axles are either 1" or 1 1/8" and we have 8 speed trannys with both.
