BMW1
D Series Replacement Gauges
BMW1
What brand of gauges are D series owners using for replacements?
I would like a matched set for a D200(oil pressure, transmission temp, volts or amps) with lights.
The ones on mine are in bad shape and don't work, except amps.  I think the sending units may be bad or maybe the inside of the gauges are bad from sitting outside for so long.
Thanks.
pfrederi
I used Sunpro.  One thing, you can use mechanical or electric for Oil pressure.  For the temp you have to use electrical  There isn't room in the hydro pump head for a mechanical head.
Sarge
Paul is correct - no way in this world would a mechanical bulb fit inside that pump head, not to mention the top of them are larger which would interfere with the Sundstrand's tapped ports for the hydraulic lifts. I used a SW electric hydraulic oil temp gauge for mine since the original went totally whacky. Plan to add a matching voltmeter, oil pressure as well. Be aware, SW's newer gauges are not US made, so the quality isn't what it used to be. You can score individual old school "tombstone" needle SW gauges once in a while on eBay - but be prepared to shell out some serious money for those vintage old school US made look.
Sarge
BMW1
Thank You for the information.
bo dawg
I found a nice chrome ring volt gauge at Rual King store for mine just last night. Looks really good with the stock oil temp gauge. But they had a pressure and temp gauge there of same mfg. They looked good too. You can see pic on my post “volt meter readings”
Edited by bo dawg
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
