Kevvc203 0 #1 Posted September 21, 2018 Looking to pick up a 42l” plow for my 257H. Are they all interchangeable or do I need the specific model # Share this post Link to post Share on other sites
953 nut 57,885 #2 Posted September 21, 2018 This list will tell you what imp laments will fit your . Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #3 Posted September 23, 2018 The model supplied back in the day was model 06-42BK01 and there is limited info on it. If you read through these links you will know all that I do. There appears to be other models that are suitable. Click on the fuzzy pictures to start with for each one Good luck in your search. Garry Adding The word compete added to the files description just means that model number included everything for the assembly. Some earlier models came in two packages with different model numbers so they could mix and match to fit the different tractors. Problem was looking at model numbers there was no way to tell if there was two packages or one package for a particular application. Once I figured them out I added the compete so we don't have to go through that again. Share this post Link to post Share on other sites
