ray loyd
deck
ray loyd
how hard is to put a bearing in a deck ?and where could i get two .you all have help me before .thanks
JAinVA
Might help if we knew which deck.The more information you give us the more help we can be.
ray loyd
ON a c81 32 inch or 36 inch ,thanks .And do you think my 8HP c 81 would pull a 42 inch of a gt1600 ?thanks so much!
daveoman1966
Toro MPV does not list a 42" deck for the C-81 tractor...only a 36" side or rear discharge.  Here is the link for attachments.
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Enter your model # of C-81, then clik to the next page for attachments...
Edited by daveoman1966
daveoman1966
Your 36 side or rear deck requires bearing # 106084 and 106085.  I have both NEW available....up to 3 sets if needed.
my direct email is:
daveoman@windstream.net    for price quotes on these NEW bearings.
  • Similar Content
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
