GreenMntRanger 38 #1 Posted September 15, 2018 (edited) Will a 48" dozer blade (Model #: 79252) hook right up to my 414-8? Edited September 15, 2018 by GreenMntRanger Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted September 15, 2018 No. 79252 is intended to fit the 260-Series 1986-on from this list would fit perfectly. DNA 76-42BC01 (1977) replaces 1965 model BD-4264A, 1966-67 model BD-426, 1967 model BD-4267, 1968 model 6-1111, 1968 model 6-2111, 1968 model 6-4111, 1969 model [6-4112 & 6-9621], 1970-73 model [6-4113 & 6-9622], 1973-74 model [6-4113 & 6-9623], 1974 model [6-4114 & 6-9624], 1974 model 6-2131, 1975 model 6-2132, 1976 model 6-2133, 1976 model 66-42BC01 76-42BC01 (1977) replaced by 1978 model 86-42BC01, 1979 model 96-42BC01, 1980 model 06-42BC01, 1981-84 model 06-42BC02, 1984-89 model 06-48BC01, 1990 model 06-48BC02, 1991-93 model 06-48BC03, 1993-2001 model 79350 and 2002 2004-2009 2012 model 79364 Garry 1 1 Share this post Link to post Share on other sites
GreenMntRanger 38 #3 Posted September 15, 2018 6 minutes ago, gwest_ca said: 1984-89 model 06-48BC01, 1990 model 06-48BC02, 1991-93 model 06-48BC03, 1993-2001 model 79350 and 2002 2004-2009 2012 model 79364 So these, correct? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #4 Posted September 15, 2018 7 hours ago, GreenMntRanger said: So these, correct? Yes. The older ones fit but may need a bend or two in the angle lever to clear the footrests. When you find one make sure you get the rear axle hitch and possibly a lift link if it used a solid one. Best to study a parts list so you are familiar with them. Garry Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #5 Posted September 15, 2018 3 hours ago, gwest_ca said: No. 79252 is intended to fit the 260-Series 1986-on from this list would fit perfectly. Garry Garry is correct that's it's not intended to fit but with a little bit of fabrication it will fit just fine as I converted(removing the unneeded parts and adding center lift point) one over myself a couple years ago, if the price was right and you can weld and fabricate the needed part (basically the center lift link) then this may be feasible, 1st pic right off a 260 series, next are after I converted, and last B/C3/400 series frame, Jeff. 2 Share this post Link to post Share on other sites
ebinmaine 67,277 #6 Posted September 16, 2018 15 hours ago, gwest_ca said: make sure you get the rear axle hitch @GreenMntRanger I have an extra rear hitch mount bracket... Maybe even the mid point pieces. If you find a plow without it let me know. I'd give you a great deal. @WV Hillbilly is spot on with his fabrication advice. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #7 Posted September 16, 2018 @ebinmaine, thanks for the encouraging words, this little bit of fabrication only requires a tape measure a drill or drill press, a hack saw or grinder and and welder or if using angle iron it could be bolted in place, very simple conversion, @Machineguy, I'm sure with your access to a machine shop these parts are child's play just like when I had full access to a machine shop, my biggest point is that with lots of attachments were not specifically made for a certain model but close enough that it won't bust the budget to make it work like this in this scenario, but others make be too cost prohibitive, ask the right questions get good answers here, Jeff. 1 Share this post Link to post Share on other sites
