TonyToro 1,049 #1 Posted September 13, 2018 I was wondering if the the 8 speed rear end was stronger or the same as a 4 speed? I have the chance to get a 4 speed and was going to use this for a puller. Any thoughts would be appreciated. Thanks. 1 Share this post Link to post Share on other sites
prondzy 3,881 #2 Posted September 13, 2018 The only difference between the 4 and 8 speeds is the use of low gear, possibly 1 inch vs 1 1/8 inch axles depending on the models each transaxle is out of. Share this post Link to post Share on other sites
Shynon 7,459 #3 Posted September 13, 2018 4 pinions 1" axle in 4 speed, 8 pinions 1 1/8 axle in 8 speed. 8 speed better IMO 5 Share this post Link to post Share on other sites
TonyToro 1,049 #4 Posted September 13, 2018 Ok....great information. Thank you! I’m glad I asked before I made another mistake. Lol 1 Share this post Link to post Share on other sites
Spareparts 84 #5 Posted September 13, 2018 I'am glad this came up, I am thinking of dropping back to a 4 speed , less gears equalls to less drag Can I put 1 1/8" axles in the 4 speed and can I use the 8 pinion diff out of the 8 speed. Thought about doing some experiamenting (SP) and picking up a 4 speed to learn with, but if someone has done this that would be cheaper. We have a speed limit so I only use 2nd gear @ 3000 rpm in the lighter classes and 4000rpm in the fast classes. What are your thoughts. 1 Share this post Link to post Share on other sites
TonyToro 1,049 #6 Posted September 14, 2018 11 hours ago, Spareparts said: I'am glad this came up, I am thinking of dropping back to a 4 speed , less gears equalls to less drag Can I put 1 1/8" axles in the 4 speed and can I use the 8 pinion diff out of the 8 speed. Thought about doing some experiamenting (SP) and picking up a 4 speed to learn with, but if someone has done this that would be cheaper. We have a speed limit so I only use 2nd gear @ 3000 rpm in the lighter classes and 4000rpm in the fast classes. What are your thoughts. Good thought. The case looks the same. Share this post Link to post Share on other sites
ebinmaine 67,507 #7 Posted September 15, 2018 On 9/13/2018 at 7:26 PM, Spareparts said: Can I put 1 1/8" axles in the 4 speed and can I use the 8 pinion diff out of the 8 speed. Not sure about the differential. I'm thinking you'd have to machine the ends of the axle tubes to accept the larger bearings. 2 1 Share this post Link to post Share on other sites
dieselpuller 4 #8 Posted November 4, 2018 The 8 speed is better I think it works for me. My buddy (wheel Horse Dealer ) used to pull in the 70,s He used parts from 1054 rearends in his 8 speed Raider .Walt 2 Share this post Link to post Share on other sites
TonyToro 1,049 #9 Posted November 4, 2018 A few of us here in Connecticut have been talking about this recently. One guy is thinking to remove unnecessary gears in the 8 speed. Less rotating mass. Another is thinking he has located bearings to accept the 1 1/8” axle into the 4 speed rear end. Then another guy has some extra special top secret super slick gear lube to pour into these gearboxes. Share this post Link to post Share on other sites
ebinmaine 67,507 #10 Posted November 4, 2018 25 minutes ago, TonyToro said: A few of us here in Connecticut have been talking about this recently. One guy is thinking to remove unnecessary gears in the 8 speed. Less rotating mass. Another is thinking he has located bearings to accept the 1 1/8” axle into the 4 speed rear end. Then another guy has some extra special top secret super slick gear lube to pour into these gearboxes. Let me just put right up in the forefront that I am by no means a Garden Tractor Puller. All of these seem like decent reasonable ideas and I'm not trying to downplay any of them ... watch this video which is using a 4-speed transmission. I have a great appreciation for the fact that you guys are trying to pull some very heavy loads. I guess I'm just kind of wondering if you're trying to fix a problem that doesn't exist yet. Are you guys breaking axles or breaking casings or breaking gears? 3 1 Share this post Link to post Share on other sites
TonyToro 1,049 #11 Posted November 4, 2018 1 hour ago, ebinmaine said: Let me just put right up in the forefront that I am by no means a Garden Tractor Puller. All of these seem like decent reasonable ideas and I'm not trying to downplay any of them ... watch this video which is using a 4-speed transmission. I have a great appreciation for the fact that you guys are trying to pull some very heavy loads. I guess I'm just kind of wondering if you're trying to fix a problem that doesn't exist yet. Are you guys breaking axles or breaking casings or breaking gears? Nice! I am really impressed what these tractors can do! We just trying something new and to get the edge on the competition. Lol We are trying to keep maximum strength and deliver the most power to the tires. These tractors were only meant to do limited work. Pulling is really pushing what the tractor was designed to do. The nice thing with Wheelhorse is that the weak link is either the belt or keyway in the axle. Our newest tractor is a 14hp engine with lots of engine work. I am going to do some more work to it before next season and have it dyno'd. We are thinking it should be around 22hp when dialed in. We pull in 3rd gear at 4000RPM. So we need to get those tires turning. Share this post Link to post Share on other sites
ebinmaine 67,507 #12 Posted November 4, 2018 2 hours ago, TonyToro said: thinking it should be around 22hp AWESOME Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,045 #13 Posted November 4, 2018 There are 8-speed transmissions out there with 1" axles. Look down this list that is in no particular order. https://www.wheelhorseforum.com/search/?&q="6 forward speeds"&type=downloads_file&search_and_or=or Garry 1 Share this post Link to post Share on other sites
TonyToro 1,049 #14 Posted November 5, 2018 2 hours ago, gwest_ca said: There are 8-speed transmissions out there with 1" axles. Look down this lists that is in no particular order. https://www.wheelhorseforum.com/search/?&q="6 forward speeds"&type=downloads_file&search_and_or=or Garry Thank you Garry I have some reading to do! Share this post Link to post Share on other sites
fast88pu 3,324 #15 Posted November 18, 2018 On November 4, 2018 at 1:32 PM, TonyToro said: Nice! I am really impressed what these tractors can do! We just trying something new and to get the edge on the competition. Lol We are trying to keep maximum strength and deliver the most power to the tires. These tractors were only meant to do limited work. Pulling is really pushing what the tractor was designed to do. The nice thing with Wheelhorse is that the weak link is either the belt or keyway in the axle. Our newest tractor is a 14hp engine with lots of engine work. I am going to do some more work to it before next season and have it dyno'd. We are thinking it should be around 22hp when dialed in. We pull in 3rd gear at 4000RPM. So we need to get those tires turning. About 50hp 3rd gear hi at 4500 rpms 1 2 Share this post Link to post Share on other sites
TonyToro 1,049 #16 Posted November 18, 2018 5 minutes ago, fast88pu said: About 50hp 3rd gear hi at 4500 rpms Awesome! Nice machine! I really like the sound of a twin and over 4000Rpm is even better!lol Are you running quick change pulleys? I need to get an assortment of those for my sons new tractor. Is that a transfer sled? Share this post Link to post Share on other sites
fast88pu 3,324 #17 Posted November 18, 2018 1 minute ago, TonyToro said: Awesome! Nice machine! I really like the sound of a twin and over 4000Rpm is even better!lol Are you running quick change pulleys? I need to get an assortment of those for my sons new tractor. Is that a transfer sled? Pulling a transfer sled. Running stock pulleys. Stock wheel horse belt and stock single spring. Leaving at 2500 rpms and no issues. 1 Share this post Link to post Share on other sites
Pullstart 62,887 #18 Posted November 30, 2018 On 11/4/2018 at 1:32 PM, TonyToro said: The nice thing with Wheelhorse is that the weak link is either the belt or keyway in the axle. You’ve broken an axle keyway? Share this post Link to post Share on other sites
TonyToro 1,049 #19 Posted November 30, 2018 1 hour ago, pullstart said: You’ve broken an axle keyway? Yes, a few months ago the keyway broke and then destroyed the hub. I guess it is fairly common when pulling, or so I have been told. Share this post Link to post Share on other sites
ebinmaine 67,507 #20 Posted November 30, 2018 Do they run 2 set screws? Share this post Link to post Share on other sites
TonyToro 1,049 #21 Posted November 30, 2018 5 hours ago, ebinmaine said: Do they run 2 set screws? The Raider I guess from new only had one large set screw but the replacement hub I got from a member here has 2 set screws. Share this post Link to post Share on other sites
ebinmaine 67,507 #22 Posted November 30, 2018 12 minutes ago, TonyToro said: The Raider I guess from new only had one large set screw but the replacement hub I got from a member here has 2 set screws. Yeah, the older ones had the light-duty Hub with one set screw. Up until the late 70s. Then there was the heavier Duty Hub like you have but with only one set screw. Sometime in the early to mid 1980s they went to a twin set screw heavy duty hub. 1 Share this post Link to post Share on other sites
TonyToro 1,049 #23 Posted December 1, 2018 10 hours ago, ebinmaine said: Yeah, the older ones had the light-duty Hub with one set screw. Up until the late 70s. Then there was the heavier Duty Hub like you have but with only one set screw. Sometime in the early to mid 1980s they went to a twin set screw heavy duty hub. As I break stuff I learn along the way! Lol Share this post Link to post Share on other sites
