ohiofarmer
  So  5b932ca08d439_jerrod001.JPG.e265008eff2f5e379dd53556aaa8b928.JPGSo  we have 16 wheels to do.lets get started.
ohiofarmer
A big 5b932ee602e71_jerrod006.JPG.91d9b7aa9bab6736762b77353f72664e.JPGvise really helps. Even then a 40 year old tire may need some lube and even heat to remove. Just heat the rim with a propane torch on the stubborn ones
ohiofarmer
Pretty nasty,with some pitting pretty deep around the valve stem. Only one way short of sandblasting to remove the rust
ohiofarmer
A battery charger electro solution, and time will take care of a lot of it. A lot of the paint comes off as well. Poly brush type wheels work better for me than steel wire wheels to remove the remaining paint,
  • Like 4
  • Excellent 2
WHNJ701
I just use a plastic tote with vinegar for a few days same results if not better for rust/paint removal
ohiofarmer
 almost all the rust has vanished or has been brushed away.  Do the wheel a favor and use metal etch. A lot of guys use  etching primer, but I spray the metal etch on and wipe it dry as soon as it turns a bit blue. Rustoleum Damp Proof red primer is old school and highly recommended by one the guys here.
ohiofarmer
So here is my wheel spinner. It is just an old MTD rear axle. I use a plywood base with a can screwed on that holds a long neck --- No, you have to save some up so you can paint sober....  the cool thing about it is that you can flip the wheel over without touching it.  Liquid laundry soap bottles hold the rear wheels and just fit the center holes fine. They taper just right so you can paint the whole wheel one coat after it flashes off.  Some short PVC pipes inside thelong neck help to keep the front wheels stable when you move them to the drying rack.
The spinner makes the paintso much more even and avoids most of the runs.
  • Excellent 5
ohiofarmer
This picture shows the sequence in painting a wheel. You do the dish and back bead. Let that paint set and flip the wheel with gloved hands to avoid skin oil.. On the finish coat it is a better idea to let the paint dry hard and do the other half the next day. My paint had hardener , so i was able to finish them all the same day
  • Like 5
  • Excellent 3
SylvanLakeWH
Nice thread and nice job!
Pics of finished product?
pacer
Doggone farmer, this is one NICE post ---- and:text-coolphotos:
And the tip for heating that rim to loosen the stuck tire is what Ive been waiting for. I have one right now that I have been struggling with, -- Thanks
KC9KAS
@ohiofarmer Thank you for the photos and the narrative on wheel painting.
I was looking at the MTD axle spinner and 1st thought you just spin it by hand, but as "Tim the Tool Man" would say, MORE POWER then I saw the cordless drill!
ohiofarmer
  I tried both a corded and cordless drill and neither one worked out as good as spinning by hand. Now if I was in the full time business of painting wheels, I would make a variable speed drive with a foot pedal input.
  Yep, those old tires are something else!  I have had them so stuck that i had to use a beveled 4x6 , heat, and drive a truck up the 4x6 ramped up on the tire to pop them loose..A Bobcat skid steer with pallet forks works also....Very quick as you can get the perfect approach angle to the tire bead
ebinmaine
Great thread with great advice !!
Thanks for the visual with the pics too.
Those wheels look really nice.
Love the spinning trick.
'farmer and @pacer and others... My honey went and bought us a harbor freight manual tire changer a few weeks ago.
That is one of THE BEST tool investments we've ever made.   ($40)
It's lag bolted to my shop wood floor through a joist. That's a MUST.
The one disclosure I'll put here is to remember it's "Manual". I'm a big guy so I have plenty of leverage to move it.
It costs $5 or more to get a tire dismounted around here so it paid for itself within just a few removals.
It works to break the bead on 8 inch wheels as well. Have to hand remove them still though.
  • Similar Content
    • Tinman1962
      By Tinman1962
      What color is this called n where can one buy some
    • ToroMan
      By ToroMan
      Evening,
      Looking for a known aftermarket paint brand and color number match for my Toro 520xi model #73542. Normally I would have the local auto paint store match a tractor part, but due to Covid, that's not an option right now. Was hoping someone can recommend a color they have used for the same tractor, as I've heard paint with the Toro label is a bad match.
      Thanks!
    • Blackhood Bill
      By Blackhood Bill
      I'm located in central Indiana. It's now on the colder side here and I'm in the middle of a project. Project now slowed down due to cold and no heated area to paint in. Just wondering what everyone else was doing in a similar situation. Would like to see pictures and maybe an explanation of how and what you have to paint inside to control overspray and paint odor.
    • JoeM
      By JoeM
      I recently acquired a C160A and the PO repainted over the factory finish on the hood. The rest of the machine looks to be pretty much original and I like the used look.
      My question, has anyone taking off a coat of paint to machine the old finish?
      Tips welcome.
      Joe
    • JHorseman
      By JHorseman
      Hey all,
      i recently picked up a Raider 8 and and Charger 12 to add to my small but growing collection. Both need restored including paint and I have never had much painting experience when it comes to auto paint. Can someone give me some helpful tips on prep , like if i need to strip it to bare metal or not and what colors to use? As well as how to mix the paint with hardener and clear coat.
      Thank you in advance!
