pazephyr
Deck attachment, 520H Wheelhorse
pazephyr
Greetings, First time here. I don't know many technical terms. I'm a farm girl so bear with me.  I purchased a used 520 H wheelhorse in 1998 (it had 200 hundred hours on it so it much be a 96 or 97) and for the most part have kept it running by just practical maintenance.  i took it in for general going over and tires/ seals etc.  1) I have a 42 inch deck. When I lower the deck to its lowest level it all but shaves the ground.  I noticed the lift bar has 2 small holes and the oval slider hole.  The lift chain is in the small hole nearest the rear wheels. Is this correct?  My belt barely clears the deck mount.  I have tried to research all this and can't find a helpful site. #2) My throttle will not stay put, l have to hold it up or it goes back to crawl.  I see all the parts but need an easy fix. Can you guide me or give to the help i need. I tried Toro site and Y tube but I'm just not very technical. thank you. Pazephyr
varosd
The throttle issue is common
you will need to get behind the “Dash” plate. The rivet loosens up
i removed the throttle knob with a claw back a hammer and 2x4 wood. Unscrew the throttle from the dash. I just squeezed the rivet with channel locks. Some preen (beat on it) with a hammer. Some drill out the riveting and put a nut and bolt. Better than the usual bungee cord throttle engineering you see.  Welcome to RS
lynnmor
Here is the owners manual, it might not be the exact model you have but the adjustments are the same:  Manual
Put a small screw thru the throttle rivet with a locknut on the opposite side.  Tighten till the throttle holds.
Cee245
Hi @pazephyr,
If you post pictures of model numbers or general pictures then we are more able to help you out.
Welcome to red square!
Ed Kennell
The lift chain should not be connected to the deck.   It should be connected to the lift bar as shown in the manual and these pictures.
The lift bar pin is then inserted into the slot in the deck carriage bar.
IMG_0017.JPG.fe7fb13cf565ba3ff4fb2b196634f976.JPGIMG_0021.JPG.9a2f47790b864fd5a6fb282283eb664a.JPGIMG_0024.JPG.9d1302ad4d5c702a35151dce9b5c5684.JPGIMG_0025.JPG.e1e32f2c45fa712211f2b92df557a977.JPG
BTW,  :text-welcomeconfetti: to the :rs:.   Hope this helps.
gwest_ca
Lift linkage
https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/73520-520-h-toro-520-h-garden-tractor-sn-5900001-5900177-1995/hydrostatic-lift-linkage-assembly/
Mower deck may be a different model but will attach the same. Click on the pictures
Garry
pazephyr
Wow, thank you all!!  Very helpful!...I will see what i can do!
noncritical
On the lift bar pin there is a hole for a pin or cotter key
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
    • firstimpauto@gmail.com
      By firstimpauto@gmail.com
      1977 C160 Automatic Tractor.  This has been my go to tractor for over 30 years.  Not a show tractor by any means. Could definitely use a tune up but still runs and mows.  Included are original manuals, 2 mowing decks, cab ( which needs all the windows replaced) including the doors and tire chains.  Someone modified the plow so it doesn't really fit this tractor.  I purchased a larger machine so do not have a need for this.  Hydraulic lift is not working.  One front tire has a slow leak.  Open to offers.  Thought I had this sold but it was someone trying to scam me with a phony cashiers check.  Please be careful.  This is the only site I have this listed so the scammer must be monitoring these ads.  Sold the rototiller. So adjusted the price.
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
