Brian1045 28 #1 Posted March 12, 2009 Hey all, I'm trying to make final adjustments to the new rebuild of my 10hp. (k241) I've adjusted the governor arm/shaft. I've adjusted the high speed mixture to where the tractor just starts to make a "rich" sounding backfire then I turn it in 1/4 - 1/2 turn before it starts to miss. My issue is in the book it shows the governor linkage spring in the 3rd hole from the bottom and all specs say to put it in the second hole from the bottom. Where do most of you run yours? I understand that the higher up the spring is on the arm the more responsive the gov. will be under a load. I 've tried both places and I'm still getting just a tad of surging/hunting from the carb. It's really hard to find that sweet spot. Should I go higher on the arm?...say 4th hole? Any suggestions will be appreciated! Share this post Link to post Share on other sites
Brian1045 28 #2 Posted March 13, 2009 Anyone got a link to a really good Carb. adjustment page? Thanks! Share this post Link to post Share on other sites
wallfish 17,080 #3 Posted March 13, 2009 Here's the page from a manual. You can find the service manual online or I can email it to you Share this post Link to post Share on other sites
Brian1045 28 #4 Posted March 14, 2009 Thanks John for the page. I actually ran into a bigger problem. The aftermarket fuel pump we used broke the internal arm that moves the pump. The new pump that broke doesn't have the primer arm either. Seems like I read somewhere these plastic pumps aren't very compatible with k241 motors. I'll need to check into this further in the morning. Share this post Link to post Share on other sites
