Similar Content
By Jeff_B
Where's your go-to source for QUALITY 103119 bearing shaft assemblies? Also, I don't have my deck apart yet, but seem to remember they're tough to remove from the housings. Any tips or tricks? Finally, just recently I've had a couple of the center bearings go loose on two different decks. Once is one thing, but twice? More than a coincidence? Should I be releasing tension on the belt by loosening the mule drive when not in use? We've had WH tractors for over 40+ years and I've never done that before! THANKS in advance!
By RichInWalworth
Question. I have a 1990 single stage snow thrower for my 312-8. I am trying to replace the bearings on the drive shaft. How do you remove them? I have taken out the set screw, soaked the collar in pb blaster, put some heat to them, pounded on them. etc. They will not move. Am I missing something? The only thing that is curious is, there is only one set screw in each bearing collar. There appears to be a second partially drilled hole but no set screw installed and it does not appear to be tapped. What gives???
Rich In Walworth
By porschpow
Good Morning everybody!
I am in the process of sharpening the blades for my mowing deck (Model 78360 - Serial 7904987) and I noticed that the deck has a crack in it right where the bracket to the mounting hardware (to the tractor) is. SO I know I have to get that repaired.
But while I was at this, I thought I could do a good quick once over on the deck to make sure I am ready for the season.
What I would like to do is the following:
Change the bearings for the spindles (or pack them with more grease)
Get new rear tires (since they squeak)
And that's about it
If anyone here thinks I should do anything else, I would love to hear it!
Where does everyone get the hardware (bearings, wheels for these rebuilds?)
By mkueb
Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor? There are two push in bearing units (inner and outer) per wheel. I first attempted to replace with standard bearings but quickly found out these are not standard sizes. It's been a while since I check and I don't completely remember, but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing. At the time, I remember finding bearings but they wanted somthing like $100 for each bearing. I was able to located two bearings and did purchase them for a reasonible price, but am still looking for two for completing the set. The part numbe ron the two that I was able to locate is 104396. If anybody has any ideas, I would appreciate.
Thanks
Marc
By Horse playing
Hello, everyone and thank you in advance. I got bit by the bug a few months ago and bought a 1974 b 80 the rod broke, about a month after i bought it. So to keep my 4yr old mowing i picked up a c120 auto and i was going to change rear wheel seals pulled the hub to find the axle moves up and down and side to side about an 1/8" what's involved in put in new bearing and does it need to be done now or a winter project. Thanks
PS sorry about the grammar
