CTR
312 8 Wheel horse
CTR
I have a 312 8 Wheel Horse that i have
Had for 16 years and thé belts are thé ones that came on thé tractor.I am having problèm finding thé belts. Any hélp would be great.
JAinVA
The manuals for your machine are on this site.Look up your model for WH parts number for your belts.This can be done from PartTree.com as well.If you do an E-bay search with the WH number aftermarket belts are offered.I do this as there is no Toro/WH dealers nearby.
953 nut
:WRS:
The Wheel Horse part number for your drive belt is 7473 which is a 5L-820 belt. I have had good results using the Kevlar belts from Tractor Supply.
Edited by 953 nut
  • Like 4
Racinbob
:text-yeahthat: When it comes to the drive belt I, in the past, have always suggested using only Toro belts and aftermarket are fine with all other belts. I have discovered, like Richard, that the Tractor Supply Kevlar belts work just as well as Toro belts on the drive. :)
gwest_ca
Are you looking for more than one belt?
Mower belts are specific to the mower - not the tractor.
How many blades?
What is the width of cut - not the width of the deck? 36", 37", 42" or 48"
Side or rear discharge?
Garry
SylvanLakeWH
:text-welcomeconfetti:
I use the Tractor Supply kevlar belts and have had very good performance...
:twocents-02cents:
  • Similar Content
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
    • Tim Fenn
      By Tim Fenn
      I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but  according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
    • FrankenCub
      By FrankenCub
      I'm new to Wheel Horse, got a fair deal on a 312-8 this week. I have some questions for you pros here, I'm a Cub Cadet junky lol.
      I'm not positive of the year, thinking maybe '84-'85? Unfortunately I didn't think to take a picture of the serial tag and it's at our other property right now. Has a steel frame, not stamped, so I guess it's before Toro got involved? 12hp Kohler Mag, great engine! It also has a 42" rear discharge deck, rough shape but I like the rear discharge. Got it running yesterday and figured we'd give a test workout, went pretty well. Today got into some damp grass that bound everything up, figured that would happen. The PTO clutch started getting hot from slipping and spit out pieces of the facing so I'm sure it wasn't in great shape, and blew the PTO belt.
      Just to get it going again without spending huge cash for top tier belts, where can I get them other than Toro? NAPA maybe?
      If you guys know off hand the belt numbers or sizes for the PTO and the 42" rd deck that would be great. Also going to need a PTO clutch disk if you could point me in the right direction.
      If I get back over to our other property this weekend I'll get some pictures, she's a tad rough but not bad.
    • Shea Worden
      By Shea Worden
      Where can I find a good new drive belt for my wheel horse? I cant seem to find any online or anywhere else. I figured I would run it by you guys and see what surfaces.
