Goat 2141
Adjustments pto
Goat 2141
Have 520h with 42" snowblower is a way to make adjustments on it the belt to loses.
Ed Kennell
Pictures would help.
gwest_ca
Did you see this post?
Garry
Goat 2141
Here's my  pics
Ed Kennell
Everything looks correct in your picture.   A couple things that may cause the belt to jump off.   Vibration from an unbalanced auger, or a weak tensioner spring, or a piece of debris in one of the three VEE pulleys.    Check each Vee pulley carefully and make sure there is not something lodged in one of the Vees.
  • Excellent 3
WHX??
Agreed Ed, tension spring looks to be a bit unloaded tho? Too short on the belt?
Good pics Goat
Edited by WHX20
Goat 2141
How would you balance it I got this .
Goat 2141
Good pics Goat
Ty
Ed Kennell
Well, an unbalanced auger is usually caused by a bent auger shaft that is causing the auger to run out.   Look at the gap between the auger "paddles" and the housing as you slowly turn the auger.  If the gap is not constant, the auger is running out and could cause the vibration.       Bad bearings in the auger or jack shaft could also cause a vibration.
Goat 2141
Ty all for the  help maybe take a short video to it .
  • Similar Content
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
    • DMB41
      By DMB41
      Hi All,
      My first post on here so apologies in advance for any rookie mistakes.
      First off, I am the proud owner of a "new to me" 312-8. I took it out for a spin yesterday and when I engaged the PTO, currently there is a 42 in side discharge mower deck on it, there were sparks flying from the disk directly below the muffler (maybe the flywheel or clutch?). Any idea what that may be and what needs to be addressed?
      Thank you !!
