Countdown To Christmas!
stevebo
Is there any 3/4" ID trans pulleys?
stevebo
Does anyone know if there are any 3/4" ID (shaft) pulleys that are stock parts from wheel horse?
daveoman1966
I used to have 2 or 3 pulleys with 3/4 ID hole...will have a look in the am.  What OD are you looking for???
stevebo
5-6” range
gwest_ca
Recorded any info that I thought was important many years ago from a site named Milaca before it disappeared so don't know the accuracy.
6.500" OD x .750" ID - # 100425 - Transmission Manual Unidrive B-80 4-spd, Commando 800 4-spd, 8hp 4-spd, WorkHorse 800. These use a 5/8" belt
I think the early Sundstrand hydros used a 5-1/4" OD pulley that may have a 3/4" bore # 6109.  Transmission Auto Sundstrand 875, 1075, 876, 1076, 1276, 877, 1077, 1277. These use a 1/2" belt
The first Chargers may have used the same pulley # 7446 but with a 5/8" belt. I don't know the OD of this one.
Garry
stevasaurus
Steve, check out this for sale add from a while ago...  :)
