David Young 1 #1 Posted August 17, 2018 (edited) my transmission will not go into gear . Just changed drive belt everything looks good ,just wondering how to check transmission oil and where is it on a A 90 1977 wheel horse Edited August 17, 2018 by David Young Share this post Link to post Share on other sites
BOB ELLISON 2,981 #2 Posted August 17, 2018 Welcome to Redsqure Another Michigander. Your transmission I believe is a peerless . Depending on the year this may help. Maybe the year of yours and a picture will help Share this post Link to post Share on other sites
SylvanLakeWH 25,957 #3 Posted August 17, 2018 to another Michigander! You are in the right place for help! Share this post Link to post Share on other sites
953 nut 55,808 #4 Posted August 17, 2018 This manual should be helpful. Share this post Link to post Share on other sites
Howie 892 #5 Posted August 18, 2018 Those Peerless transmissions actually hav e grease in them, and don't believe there is a way to check them. most of them I have been around you can not check. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #6 Posted August 18, 2018 Worked OK before you changed the belt? Now it doesn't? Good chance the drive belt is not coming to a stop with the clutch pedal pushed down. It must stop before shifting. The 1974 A-90 Special model 2-4300 used the 1400 Peerless transmission The 1976 model 62-08BP01 used the 648 Peerless transmission posted above. The 1977 model 72-08BP01 used the 662 Peerless transmission Garry Share this post Link to post Share on other sites
David Young 1 #7 Posted April 10, 2019 I did change the drive belt old one did not know the size. read that you have to push brake and clutch pedals at same time. My brakes are gone that's why I'm putting on new brakes. Share this post Link to post Share on other sites
