Skwerl58 702 #1 Posted August 14, 2018 I have had my tractor about 8 years and purchased from original owners estate with low hours. It included the mowing deck , push blade and manual lift with the clevis hitch. I have been picking up attachments and finally got a tiller from the early 90's and mounted it. I used info from this site to mount the tiller and after mounting I remembered that I saw a shaft with some slots in the accesories I received with the tractor. My question is will the newer style rocker shaft with the slots be a correct replacement for my older shaft that only hooks to the clevis chain in one place? Great site and thanks for any help that you can provide!! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted August 14, 2018 It should fit. The slots were provided to easily adjust the lift height but it also increases the effort required. Garry 1 Share this post Link to post Share on other sites
Skwerl58 702 #3 Posted August 15, 2018 Thanks for the quick response, I will leave well enough alone and if any issues arise I will replace with the other one. Share this post Link to post Share on other sites
KC9KAS 4,741 #4 Posted August 15, 2018 @Skwerl58 to Share this post Link to post Share on other sites
rjg854 11,350 #5 Posted August 15, 2018 and seeing no one else has mentioned it, Share this post Link to post Share on other sites
Lee1977 6,643 #6 Posted August 15, 2018 If the gas tank on both tractor is located under the seat It will work. The tractors from 1977 back used a longer rocker it will not fit the later models because it's too long. Share this post Link to post Share on other sites
