Phil Burley 4 #1 Posted August 14, 2018 can any one please tell me the length of a drive belt for a 4 speed Wheel horse , model 1-0394 . easily available in USA but tricky here in UK without knowing the length regards Phil Share this post Link to post Share on other sites
pfrederi 17,886 #2 Posted August 14, 2018 5/8" x 81.95" 2 Share this post Link to post Share on other sites
Phil Burley 4 #3 Posted August 15, 2018 hello thanks , so its an A section x 82 inch . I will order one off ebay regards Phil Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #4 Posted August 15, 2018 A 5/8" wide belt is a "B" section belt. And watch the length. A true B-82 is 85" long and a true B-79 is 82" long. You will also find B-82's that are 82" long. Garry Share this post Link to post Share on other sites
Phil Burley 4 #5 Posted August 16, 2018 oh , so the cracked A section one that was on mine is wrong then , the pulleys looked a but narrow for a B section .I will look for one on ebay thanks again , Regards Phil UK PS I had a bit of a trundle round till the belt snapped , care of a Briggs and Stratton engine just to rest the box , some problems there , it doesn't want to go into top gear ! Share this post Link to post Share on other sites
953 nut 55,822 #6 Posted August 16, 2018 The 5L-820 is 5/8" wide and 82" long (same as the B-79). Here in the states Tractor Supply has Kevlar jacketed belts that work exceptionally well. most will have both the B-XX and 5L-XXX sizes listed on the sleeve. Share this post Link to post Share on other sites
Phil Burley 4 #7 Posted August 19, 2018 Hello .,thanks for the information , at present we are using a non standard engine , but we cant seem to get enough slack in the belt when de clutching to stop the gear box pulley turning , which makes getting into gear difficult . When using the correct parts , will the gear box input shaft stop when the belt slackens . or is it our gear box problem , I know we still have a problem there because we cant get top gear at all , still too much end play in the shaft . regards Phil in the UK Share this post Link to post Share on other sites
pfrederi 17,886 #8 Posted August 19, 2018 Do you have the belt guard installed??? Also many WHs had wire guards mounted on the engine to keep the drive belt in eh correct position when clutch was depressed. Share this post Link to post Share on other sites
Phil Burley 4 #9 Posted August 20, 2018 hello,. do you mean that metal plate over the top of the idler pulley ? I put that back on in maybe a different position than the original . I will try moving it round a bit tomorrow and see if that makes any difference regards Phil in UK Share this post Link to post Share on other sites
pfrederi 17,886 #10 Posted August 20, 2018 Actually I meant the belt guard that covers the whole side of the tractor. It must be on for the the system to work Also there are tabs at the front end of it that need to be bent very close to the belt. The bracket you mentioned could also be an issue make sure it isn't dragging on eh belt when clutch is depressed. 1 Share this post Link to post Share on other sites
