LFDRET 21 #1 Posted August 12, 2018 (edited) Does any one know where I can find axle seal for a 1975 B-100 automatic and a 1978 C-161 automatic Edited August 13, 2018 by LFDRET Share this post Link to post Share on other sites
ol550 830 #2 Posted August 12, 2018 Just look at the bearing and seal cross reference pinned at the top of this section. If you need part numbers just go to the manuals section. 1 Share this post Link to post Share on other sites
LFDRET 21 #3 Posted August 13, 2018 My wheel Horse part manual for the C-161, calls for seal 6449. But I can not find the B-100 auto parts manual. Or a cross ref. to 6449. need Help!!! the seal cross ref. I only see 4 & 8 speed, no Automatic cross ref. Bill Share this post Link to post Share on other sites
ebinmaine 68,433 #4 Posted August 13, 2018 Perhaps @stevasaurus knows? Or... Have you called Lowell? Wheelhorse parts and more. One of our vendors. Great guy. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #5 Posted August 13, 2018 Click on the pictures 1974 tractor model 1-0510 axle seal WH # 100607 = SKF/Chicago Rawhide # 9878 - 1" ID, 1.5" OD x 1/4" wide 1975 tractor model 1-0511 axle seal WH # 100607 = SKF/Chicago Rawhide # 9878 - 1" ID, 1.5" OD x 1/4" wide WH # 6449 = SKF/Chicago Rawhide # 11124 - 1-1/8" ID x 1-5/8" OD x 1/4" wide Here is a SKF/Chicago Rawhide interchange for all seals http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm Garry Share this post Link to post Share on other sites
stevasaurus 22,871 #6 Posted August 13, 2018 Garry got it for you...the 6449 is SKF 11124 and it would be the same for both horses. I am editing this to say that the above is not true...it seems he has 1" axles on the B-100. Sorry. Share this post Link to post Share on other sites
pfrederi 17,886 #7 Posted August 13, 2018 You might also try National (Timken) 471652. I started using those on my Sundtrands. The outer lip seems more pronounced...may keep more crap out CR green Timken red 1 Share this post Link to post Share on other sites
LFDRET 21 #8 Posted August 13, 2018 My wheel Horse part manual for the C-161, calls for seal 6449. But I can not find the B-100 auto parts manual. Or a cross ref. to 6449. need Help!!! the seal cross ref. I only see 4 & 8 speed, no Automatic cross ref. Bill Thanks guy's your the best Bill 1 Share this post Link to post Share on other sites
stevasaurus 22,871 #9 Posted August 14, 2018 Those cross reference numbers pinned at the top are only for manual transmissions. I think if you read through the whole thread, we do put that #6449 seal information in there. Share this post Link to post Share on other sites
LFDRET 21 #10 Posted August 14, 2018 On 8/13/2018 at 5:04 PM, LFDRET said: My wheel Horse part manual for the C-161, calls for seal 6449. But I can not find the B-100 auto parts manual. Or a cross ref. to 6449. need Help!!! the seal cross ref. I only see 4 & 8 speed, no Automatic cross ref. Bill Thanks guy's your the best Bill the B- 100 Auto has a 1" axle does anyone have a cross ref. for this size Share this post Link to post Share on other sites
ebinmaine 68,433 #11 Posted August 14, 2018 My 1974 b80 has 1 inch axles in a 4-speed manual. Maybe the chart would give you the correct seal number using that information? Share this post Link to post Share on other sites
pfrederi 17,886 #12 Posted August 15, 2018 49 minutes ago, LFDRET said: the B- 100 Auto has a 1" axle does anyone have a cross ref. for this size Gary gave you the number earlier in the thread 2 Share this post Link to post Share on other sites
stevasaurus 22,871 #13 Posted August 15, 2018 I was wondering if Wheel Horse made a transmission for autos that had 1" axles. I thought all hydros had 1 1/8" axles. I just hate learning something new everyday. 1 Share this post Link to post Share on other sites
ebinmaine 68,433 #14 Posted August 15, 2018 20 minutes ago, stevasaurus said: I just hate learning something new everyday. I know what you mean Steve. Right there with you. It's okay. Just take a deep breath and we can get through this together. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #15 Posted August 15, 2018 The 1974 B-100 Automatic parts list above states the transmission model is a 5090 on the second page that lists all the transmissions including the C120 and C-160 Auto models. So there is at least 2 automatic models with 1" axles. The 1975 manual is for the B100 Auto model only. Found 1972 Charger 10 model 1-0410 uses 5090 transaxle with 1" axles. 1973 10hp Auto model 1-0475 uses 5090 transaxle with 1" axles. 1973 10hp Auto model 1-0470 uses 5087 transaxle with 1" axles. Total now 5 automatic models using 1" axles I posted links to both B-100's because I did not know which B100 Auto he had. Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #16 Posted August 15, 2018 Always wondered what the WasteWatcher seals were. You will see it listed on the 9878 seal page posted above. Garry Share this post Link to post Share on other sites
LFDRET 21 #17 Posted August 17, 2018 I got my seal from Motion Ind. Just want to thank you all for the help Bill 2 Share this post Link to post Share on other sites
