Similar Content
By r1jakecfd
Hi Guys,
The Onan in my 520H was running poorly so last month I took the heads off, decarboned, cleaned/reseated the valves, checked valve seats and reassembled with new gasket set. When installing intake manifold, I realized last year (carb cleaning) I forgot to hook up vacuum line from manifold to gauge. Hooked it up correctly this time and ran great. First blizzard yesterday and started snow blowing. After about 15 minutes the became noticeably louder with less power.
I was wondering firstly if anyone has any idea what went wrong?
Also, I was thinking about repowering with a Honda or Vanguard and would love opinions on which way to go? Also, should I go with an engine or kit and which company? I’m good at fabrication, etc.
Thanks in advance!
Happy NewYear
By Team70R
Finally got the Honda Horse dialed in! Even with the factory 6:1 gear reduction on the G300, this thing plows perfectly! Just it will actually plow at an idle in 3rd gear. Doesn't even sputter! Can't wait to hook the dozer blade up to see what it can push
By Team70R
Looking for a new drive pulley for my Honda horse but can't find any pulley online with a 7mm keyway! Anyone have any tips? Anyway I could make a 1/4" keyway bigger? Shaft size in 1"
By Team70R
Finished the Honda swap on my 606 and finally got new tires on it! Went for a test drive and it's all revs and no speed! The Honda pulley is a little bigger than the factory Tecumseh pulley so I thought it would be faster! What the heck is going on?! Belt isn't slipping because it'll spin the tires in every gear when I hooked it to my jeep
By Team70R
Finally got fed up messing with the old HH60 and pulled it off my 606. Slapped the Honda G300 on, which I have $0 in, and got everything working! Just have to set up one of the old Tecumseh gas tanks and modify the exhaust so the hood will fit WITHOUT cutting it. Should be a work horse now!
