bo dawg
3 point hitch
bo dawg
Is the 3 point set up w/cyclinder off a D tractor same as on the C-195 ?
"D"- Man
I know some of the parts will swap, but not all.  The cylinder should be the same.
bo dawg
Do you know which parts will?
"D"- Man
I am not certain, but I think a least the bracket that holds the top link is unique to the modei, and possibly the bell crank.
ronwh
Bo,
If you pull up a parts diagram of a C-195 3-point hitch you will need item #1, item 2 and item #11+ hardware to install a D 3-point hitch on a C-195.
#1 109787 lift bar assembly
#2 109786 block
#11 109791 assay upper link pivo
Hope this helps
Ron
bo dawg
Here’s what’s on it now, which is not much.
Edited by bo dawg
