By
JoeM
I have a C145 hydro and when I engage the trasmission belt, the engine goes into the governor. The hydro control is in neutral, and the machine is not moving. The tractor will move foreward and reverse and seem be be responsive. But the engine seems to be loading the entire time. I have two other C145's and so no sign of this problem. The problem is the same cold or warm oil. I just purchased the machine, (knowing there was a transmission problem), and have done nothing more thean check the fluid. It is full and seem to be the right grade. I thought about an oil change, but thought I would throw this out to the forum to see if anyone else has had this problem.
Any suggestions?
