Countdown To Christmas!
FatJackDurham
520H Where is the tow release valve
FatJackDurham
is there a hyraulic release valve so that you can pull a 520? Where's it at?
19richie66
If it has the eaton 1100 it should roll freely. All of my eatons push with no problems.
lynnmor
My 520H tractors do not roll easily and there is no tow valve.
Kurt-NEPA
I'm with lynmor, my 520H's don't like to be towed.  You can move them a bit, but they complain.  No release for towing.
953 nut
You can move it around in the shop or load it up without a problem but I wouldn't toy it very far without a dolly under the rear tires. Too many internal parts turning without lubrication.
WVHillbilly520H
As the operators manual states as well as a decal that "used" to be on the unit..."HAND PUSH ONLY DO NOT TOW" DAMAGE MAY RESULT!...now let's say you get yourself stuck , yes you can tow it enough to get the unit out of a jam, Jeff.
KC9KAS
I did read in the manuals that a 518 Hydro (1100 Eaton) could be pushed easier IF you put the motion control lever in the fast forward position. Sure was hard to load with 2 flats in the front and the rears sliding....THEN I read the manual!
  • Haha 2
roadapples
Been there done that too...:bitch:
lynnmor
I tried putting the motion control lever in various positions to help with towing and found no position helps very much.
19richie66
Brake maybe too tight or dragging? Just a thought.
FatJackDurham
THankx all!
gwest_ca
This is taken from the 1993-1996 520-H operator manual
Garry
