Macgyver
Rear implement lift for 520H
Macgyver
I have a 520H with the rock shaft & cable in place. The rear hitch does not have much up down travel. After studying it for a while I decided to bypass the rock shaft and run the cable direct to the hitch. The hitch now has about 4" more travel. Has anyone else tried this and can anyone come up with a down side to doing it this way?
cleat
Did you have the chain in the correct notch in the rock shaft ?
Bottom notch will give you the same movement you are talking about now.
Is your cable the correct length ?
Trunion adjusted properly ?
lynnmor
Without the rockshaft, the cable will not have the leverage advantage and that will put much more strain on it.
Macgyver
There are no notches in the rock shaft the chain has a fixed mounting and yes have made all the adjustments that can be done. My question is there any problems with running the cable direct to the hitch it seems to work fine with more travel.
gwest_ca
Don't know what model of hitch you have but this was a modification for an earlier model. Click on the pictures
Going straight to the tiller will likely increase the effort to lift.
A later version
Here is a later one with the notches
The last version
Garry
