dlpaw
Help mounting mower deck to '62 Lawn Ranger
dlpaw
Hello friends,
We have a '62 lawn ranger, and a couple of years ago we bought what should be an original mower deck from another '62. The time has come to see if I can fix the deck up and install it. I have been looking for information on how to correctly mount the four separate pivot arms to the frame. Two of our pivot arms have shoulder bolts on the frame mount ends that allow the arms to pivot at the frame, and the other two have regular, non-shouldered bolts with lock nuts. I did a search of the forums, and found photos of how the deck mounts on the later 60's models, but the earlier deck that we have has some differences in construction. Some pictures or a diagram of the attachment points for a '62 lawn ranger may help us make sure everything is in the correct position.
Second issue...The two mower blades on our deck are mounted so that as they spin, the tip of the blades touch each other slightly as they go through their revolutions. Should the blades be clocked differently so that they have no chance of contacting at the tips while spinning, or am I just seeing the results of worn bearings, or bent or incorrect blades?
The mower deck that we have appears to be the same as the one in the attached pdf file from the archives on this site.
Thanks in advance for any help that you can provide.
Daniel
Mower Rotary 32in RD 1962-63 RM-113 IPL.pdf
CasualObserver
The mounting instructions are in the Lawn Ranger manual.....
CasualObserver
and yes, on those timed gear decks the blades should be at 90 degrees from each other.
dlpaw
Wonderful! Thank you so much for this info, knowing the bolt hole locations will be very helpful.
If I was to retime the blades under this deck to be at 90 degree, is it accomplished in the gear housings by changing which gear teeth are engaged, or by unbolting the blades and repositioning them on the spindles?
Thank you again,
Daniel
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
