69 Workhorse K321 engine swap
By
Machineguy, in Restorations, Modifications, & Customizations
Similar Content
By Kyle G Cantrell
Trying to restore a 1971 Wheel horse Workhorse 800 model 0100, It has a tecumseh HH80-110112D.
I cannot find any parts at all for this one, I’ve checked everywhere I can think online. This is my first restore, looking for some help to find parts or what I can use (swap) to keep it close to original but also functional.
Also the fly wheel has two **** that stick up off it that the coil passes and one is broke off. Is that a problem, I’m a mechanic but this thing is old and with no info it’s a guessing game.
Parts needed so far:
right side running bored/footrest
Left side engine cover
right side pulley cover
Ignition coil
Main drive pulley bearings
Hitch pin (goes through trans case)
*NEW TO SITE, WILL CHANGE IF POST INCORRECT*
By drewd
I need to buy tubes or new rear tires for my 1971 Workhorse 800. It has the original 22.5x7.50-12 Wheelhorse branded tires but sidewalls are leaking and one no longer holds air for more that two days. Searching websites brings up various sizes but not the original. Would a 23x9.50-12 fit this tractor? I have a 36" RD deck on it. Any other sizes work on this rim and tractor?
Thanks!
By kdeatrick
Well, I did another Work Horse over. This one I will use weekly at my Rental property. This started out as repairing the shifting linkage and brakes. While waiting on parts, I degreased it and thought, I might as well touch up the frame paint on the frame. Then I took the sheet metal off and bead blasted it. It now has base coat clear coat paint. All tires are used and in good shape for now. I chose not to fill in the rust pitting with body filler since it is going to be used and didn't want to get more time and money into it. So it has character, looks decent and will continue to work.
By felker13
I am very new to finding old tractors so I am not 100% sure if I got a deal or not. Today at an estate sale I was able to pick up a Work Horse GT-1100 for $65. It needs a lot of clean up, and as of right now I am not 100% sure of the working condition. It did come with the snow thrower attachment, and even though it isn't pictured, I also got the mowing deck as well. Not sure what these are worth, but any info would be much appreciated! I have attached some photo in its current condition. Thanks!
