tntatro
Need help with 8 speed transmission
gwest_ca
If the bearing is an open style (a shaft would go through the bearing if the bearing was out) something you can try.
Find a solid shaft that will fit into the bearing with as little clearance as possible and expect the shaft to get damaged.
Half to 3/4 fill the bearing with grease.
Place gear/bearing assembly vertical on a solid surface.
Insert shaft in bearing.
Drive the shaft into the grease as hard as you can with a big hammer.
The hydraulic pressure created on the grease may force the bearing out.
If the bearing moves add more grease and repeat.
Garry
stevasaurus
I destroy the bearing by getting the needles to come out...then take a small, sharp screw driver and hammer in between the race and shaft.  It will rip and then fall out.  The picture you have of that bearing looked fine, I would not have replaced it.  :think:
tntatro
I decided to replace all the bearings since there was one 1533 damaged and I could tell the difference after replacing it and comparing the new one with the other side. Most of the needle bearings that I removed seemed to be fine except maybe one or two sounded loose when I shook them.
The bearings in the gear pictured seem to be the least likely to fail because they ride about even with the rest of the shaft. I may leave them but I'm not sure about the damage to the gear. I counted 17 cogs and 11 of them were crushed a little. The damage is just in the area where third gear sits. A new one is $165 so I don't think I'll go that direction but I may be able to find one on ebay or I have another 8 speed that I can take apart and swap all the best gears to this one.
stevasaurus
I would check with one of our vendors...like A-Z for that gear.  Check our vendor's list on the main page.  a good used gear like that is going for around $20 from one of our guys.  :)
tntatro
I finally got my transmission together. I actually did two. One has new bearings and a new circular spring and the other I just put a limited slip and new seals.
I haven't had a chance to run the one with new bearings and spring yet but the other does have much better traction than the regular 8 pinion but it still doesn't want to climb this one steep trail on the property where a root sticks out into the path. One tire will spin on the root while the other looks like it wants to spin but doesn't. Is this because the circular spring is worn out or is it likely that I'm pushing it beyond its limit? I tried in 1st and 2nd and it wouldn't climb but it did go up if I used 3rd and got some speed. I didn't think to try the low gears.
The other transmission is on a mower at a different property so I can't drive up the same hill for comparison.
pfrederi
It is a limited slip not a locking differential you may have a weak spring or it may be just too much.  In some circumstances my 10 pinions will s[pin one wheel...
oliver2-44
Most auto supplies rent tools and they dhould have what you need to pull those needle bearings out, which is a slide hammer puller.  It comes with several different sizes of adjustable jaws which grab the bearing   Harbor Freight also sells a set that works
tntatro
Just giving an update on the transmissions. One transmission is being used for mowing on a Raider 12 and seems to go everywhere I want it to on the lawn. The limited slip does seem to have a little more traction than the 8 pinion. The second transmission is the one that got fully rebuilt. It is on an 8 hp Wheel Horse and now has 6-12 lug tires, v-bar tire chains and a 50lb wheel weight on each side. I've noticed that usually when the tires spin that both spin at the same time. I think the wheel weights made a big difference. Now I can drive up the path I had mentioned in an earlier post and it doesn't even spin a little. I can drive right over the root in low gear uphill after it rained. I have even been pulling small logs out of the woods with it. The only problem I have is the front will lift if I go up an area that is too steep. I have to try to go up at and angle to keep the front down. I just ordered some front wheel weights for the tractor. I'm thoroughly impressed with what it can do now. I think a lot of it is the wheel weights and heavy duty tire chains, not sure how much is due to it being a limited slip although my 4 speed with 20" turf tires and regular tire chains and a 45lb weight on each side will not pull logs out of the same area.
Lee1977
On 7/13/2018 at 9:38 PM, tntatro said:
Thanks a lot, that's very helpful. I'll take a good look at the rest of the bearings before ordering anything. I still haven't taken apart the differential but I might have found a 10 pinion with axle shafts. Someone parting a Raider 10 said he'd see if it has the 10 pinion so hopefully it does and it's in good shape. They seem to be a little difficult to find.
Is the wear on the gear an acceptable amount? It looks like it is worn to a bit of an angle unless they are shaped that way originally. It did seem to shift fine the little I used it.
You have a better transmission then a ten pinion. Nrmally a ten pinion is fine, but a 8 pinion is stronger.
tntatro
After some research I learned that the 8 pinion differentials are much more durable but I decided to go with the 10 since I won't be using them for competition pulling. I still have a couple 8 pinion differentials for backup in case I do break a 10 pinion. I guess I'm pretty mental about traction. I'm finally content after getting the 10 pinion, lug tires, wheel weights and heavy duty v-bar tire chains, plus I have front wheel weights on the way.
  • Similar Content
    • SethL1984
      By SethL1984
      312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
      417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
      (1) 42" RD with mule drive. Cuts well!
      (1) 48" SD with mule drive.
      (1) 37" SD.
      (1)  48" snow plow. 5 way blade position I believe.
      Several other parts/WH odds/ends. One tractor does include the weights and chains.
      Parents are moving and, unfortunately, need to thin the herd!
    • ERBSHORSE62
      By ERBSHORSE62
      I have a 417-8 with  a bad Transmission.  Not sure how bad, but can I replace the whole Transmission with an 8 Speed from any other Wheel Horse Tractors.  Will any other models be a direct fit bolt on.  Thanks for any support.
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Ralpho711
      By Ralpho711
      I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different.  Any help is greatly appreciated. I'm brand new to the site and think its great!
    • Red144runner
      By Red144runner
      I mow 7 lawns on the side 3 are neighbors. One in is a good size and flat. The only pita is a swingset. I like using the tractor on it for several reasons, it does a beautiful job, it needs to be bagged and with I only need to empty twice, my proline 36” I empty 7-8 and it’s a good excuse to run it for 90 minutes.
