Pullstart
Shop project...
Pullstart
So, at Uncle Jim’s plow day, Norman’s “new” lift pump died a little.  It had been making a lot of noise.  The manufacturer assured me that noise is a common complaint, but there is no worry there.  Little did we all know, the motor was absolutely filthy.  Upon tearing it apart, both magnets also broke.  Well, there’s no mystery now!
Air Dog does not sell replacement parts, but I can purchase a new upgraded pump with better bearings for something like $300 with a lifetime warranty.  I suppose that’s what I’ll do.  @Achto think we can just whack it with a ratchet again?  :ROTF:
  • Sad 1
Achto
Looks like it's time to whack it with a BFH....& then replace it.:ROTF:
Sucks to buy new parts & have them be a POS. I'm having that joy with the heads that I put on my Dakota. Put it all together & it runs great at an idle, even revs up decent. No power though.:( Leak down test shows 72% leakage on cyl 1 & 50% on cyl 6, both through the intake. May never trust buying reman parts on line again.:( Torn between making them warranty them or having my local machine shop rework them. ( should have had my heads redone at my local shop but I was trying to decrease down time) Live & learn I guess.:thumbs2:
Edited by Achto
  • Sad 3
WHX??
Was that a new unit Kev? I could see a little brush dust but that is filthy.
I would have them warranty them Dan and ***** like an old lady that time of the month. Principle of the matter. Sides ain't like you ain't got a selection of trucks to borrow you need as far as down time.
  • Haha 1
ZXT
That sucks! What engine? I'm guessing a 3.9 or a 318?
:text-yeahthat: They owe him a replacement set of heads, plus compensation for having them installed (have fun getting that out of them). The only problem with that is you never know if the replacements are any better than what they sent you the first time!
Pullstart
The pump wasn’t actually new, just new to me.  The PO of the Texas truck told me through Google Translate that the pump was only 1 year old.  It looks like it was 1 year at the bottom of the gulf.
  • Sad 3
WHX??
Agreed ZXT.... how did you know they leaked throug the intake valves? So not the rings as supected? That would have been another whole can of worms!
Achto
4.7L non H.O. I purchased the reman heads from Cylinder Heads International. Didn't have a warm fuzzy feeling when I found a loose valve keeper in the bag with the Left head. All keepers were on the valves so I just inspected the right side real good & carried on. Later found a helicoil on the right head that was installed at about a 10 degree angle. It only holds the fuel injection rack down & is not crucial so again didn't make a big deal of it. Now after the valve leakage I'm really not happy.
  • Sad 4
ZXT
Ah. 4.7's are my least favorite Chrysler engine. What issues were you having that prompted a head replacement in the first place? Cracked I assume?
Sorry for hijacking your thread Kevin.
Pullstart
It’s a public thread.  Things happen.  Sounds like a shop project to me Jonah :handgestures-thumbupright:
WHX??
Don't worry about Kev ZXT ..... EB's missus takes care of my light work! :laughing-rolling:
So much for CHI's QA department eh Dan? This is why you should whine to them like no tommorow.
  • Haha 4
Pullstart
Question here.  @WHX24 @Achto @953 nut @Greentored @Redneckdavis (you still around buddy?) and all y’all old school hot rodder dudes....
Is there any amount of epoxy and clamping that will bring those magnets back from the dead?  This is a full time use pump, it never stops when the truck is running.
Achto
Burning coolant on cyl 8 to start with. Then spit the rocker arm off on cyl 7. That was one more issue I had with Cylinder Heads International. They put used valve lash adjusters in a set of heads that are known for throwing rocker arms. On one of the heads 6 of the 8 lash adjuster had no spring load to them. You could grab the adjuster and move it up & down with no resistance. I would not have that & installed 16 new Melling adjusters.
Edited by Achto
  • Sad 3
WHX??
Sucks that AD doen't offer parts. What were they held on to begin with? Is that where the noise and carnage came from?
You might find a hight strenght epoxy that would work but things would half to be really clean. and small c clamps?
Achto
Sorry to say, but in my experience once the magnets break you are generally SOL.:(
Achto
As soon as I pull them back off & inspect them again then I will make my case with them.
Pullstart
I agree Jim that they don’t offer a parts dept... but it is what it is.
Dan I am planning a 40 hr round trip soon so no reason to half fix it and hope for the best.  I’ll unfortunately just get a new pump.
Achto
 Will be your safest plan.
953 nut
I think that is your best bet, no telling where you would be when the temporary repair gives out. Fix it now and forget about it. A few months from now you won't even remember how much it cost you, but if it put you on the roadside that would be a lasting memory.
WHX??
Ah .. I see now Kev one of the mags broke in half. ...yup yer done... :sad:
WHX??
The way he packs Richard story of his whole life we fear...sometimes I think he does what he does just for the challenges!  :lol:
It's all good....
  • Haha 3
Pullstart
What’s the use of life if you ain’t livin’?
  • Haha 4
Greentored
Yep, me thinks might be best to get a new pump.
Truthfully, have never been in a position like that, so no real world experience to know what does or doesn’t work.
  We occasionally use a 2 part panel bonding adhesive in the shop that I’ve used for other purposes, and whatever you bond ain’t coming apart! Just not sure this would be the place to experiment.
Pullstart
I called the shop this morning.  $219 for the exact same pump, $269 for one with double the bearings and more seals for longer life.  Both lifetime warranty.  Funny thing, he said the 4g or g4 or whatever better one was WAY better and should expect a good 8-10 years lifespan. But it’s the best and it’s lifetime warranty?!?  I opted for the better.  This doesn’t get driven in snow and salt, plus I opted to mount it inboard of the frame to get out of direct path from the front tire in rain, rocks, etc.
It’ll arrive Monday... we’re supposed to have our camper to Lake Okeechobee by Thursday. I’m not going to stress on it.  We’ll see how it all works out!
WHX??
Well that's not terrible then ..I would have figured it to be a grand plus.
19richie66
Lake Okeechobee........ if I was still in Florida I would come visit. Be sure to look up Rodney Burger while you down there. He has LOTS of stuff hoarded up down there by now. 👍 Have a safe trip.
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
