Aretino 1 #1 Posted July 3, 2018 Will a mid mount grader blade from a C-175 fit a 314-8? Share this post Link to post Share on other sites
953 nut 55,078 #3 Posted July 3, 2018 The mid mount grader blade will work on most models as long as they have the proper attachment points on the frame or rear axle depending on the grader blade model. There is one thing we expect from new members; Share this post Link to post Share on other sites
Aretino 1 #4 Posted July 3, 2018 Thanks for the replies. Grader Blade Im looking at is in excellent condition, missing lift arm. Been looking for this attachment for several years. Thinking that making a lift arm should be possible. May need advise on size and shape of lift arm. Share this post Link to post Share on other sites
CasualObserver 3,408 #5 Posted July 3, 2018 @wheelhorseman sells top quality reproduced lift linkages. scroll down on the linked page. https://www.wheelhorsepartsandmore.com/brackets-linkages.html Share this post Link to post Share on other sites
Aretino 1 #6 Posted July 4, 2018 I ordered the lift link from wheelhorsepartsandmore. Thanks! 1 Share this post Link to post Share on other sites
CasualObserver 3,408 #7 Posted July 5, 2018 @Aretino you won't be disappointed, Lowell's stuff it top notch. now... if I can just talk him into referral credits... @wheelhorseman 3 Share this post Link to post Share on other sites
FatJackDurham 318 #8 Posted July 18, 2018 I just modified my grade blade so that it would work on my GT-14. It was the wrong length and the blade was too far back to connect to the hydraulic lift arm I have for my dozer blade. Also, the rear bar was too narrow for the GT-14 rear attachment dohicky. I cut off the back end of a sacrificial plow attachment I never planned to use, welded it on and now it fits pretty good. I had to cut new angle slots because at full angle it hit the front tires. I supposed that means I could move it backwards, but i'd have to cut out the existing bar or change my attachment bracket on the GT-14, and come up with a lift extension. But I'm happy with how it came out. I didn't like it dangling on the chain under the 416-8, I had to stand on it to get any digging power. The hydraulics of the GT-14 make it work more easily. Share this post Link to post Share on other sites
