BHunter 1,700 #1 Posted July 2, 2018 I’m changing the trans oil today but don’t know how many quarts to buy. Thanks in advance. Share this post Link to post Share on other sites
Achto 27,813 #2 Posted July 2, 2018 39 minutes ago, BHunter said: I’m changing the trans oil today but don’t know how many quarts to buy. 2qts will be more than enough. Share this post Link to post Share on other sites
BHunter 1,700 #3 Posted July 2, 2018 1 minute ago, Achto said: 2qts will be more than enough. How do you know when it’s full? Share this post Link to post Share on other sites
Achto 27,813 #4 Posted July 2, 2018 (edited) 4 minutes ago, BHunter said: How do you know when it’s full? Remove the pipe plug on the right hand side of the tranny. Fill until it runs out of that hole. Edited July 2, 2018 by Achto 2 Share this post Link to post Share on other sites
BHunter 1,700 #5 Posted July 2, 2018 11 minutes ago, Achto said: Remove the pipe plug on the right hand side of the tranny. Fill until it runs out of that hole. Thank you 1 Share this post Link to post Share on other sites
Wild Bill in VA 1,453 #6 Posted July 3, 2018 Try to get 85w-140 weight gear oil and install 1-1/2 quarts through the gear stick opening. The factory original amount was 1 quart but this found not to be enough when operating on the slant of hills. The thick gear oil also helps take up some up some of the slack from worn gears. Wild Bill in Richmond, VA 1 Share this post Link to post Share on other sites
Racinbob 11,234 #7 Posted July 3, 2018 The 3 and 4 speeds specified 1 1/2 quarts, the 6 and 8 speeds 2 quarts. Anywhere in that range will be fine as well as using the pipe plug on the right side as the manual states. I have used 80w90 in all mine for decades with no issues at all. 1 Share this post Link to post Share on other sites
