608KEB
12 HP Kohler compression question
608KEB
I bought a 1999 WH 312-8 last winter for my father. When starting it if it kills.  When he tries to restart it. It won't turn over unless he removes the spark plug to relieve the built up compression. The engine has the OHV. How can we fix this?
Ed Kennell
Have you checked the valve clearances?  They could be too loose not allowing the valves to open and release the compression.
Could be the ACR  (automatic compression release) has failed.  If the cylinder is flooded with fuel, could be a carb needle valve failure or hole in the float in  the carb bowl.
gwest_ca
Click on the picture
Garry
cleat
My 312 has a Kohler Magnum. Is the manual similar ?
WHX??
Battery, starter & cables up to snuff?? ...just a thought.
  • Excellent 1
608KEB
I was wondering if it had a ACR. Where is that located. That would be the first thing I should check.
608KEB
It won't turn over because of pressure that has built up in the cylinder. If I take the plug out. It'll turn over no problem. If I put plug back in it starts right up.
Edited by 608KEB
608KEB
Yes
953 nut
:confusion-confused:            So, when you begin to back out the spark plug do you hear the pressure releasing? It couldn't hurt to clean and tighten all electrical connections including grounds. Also, have the battery load tested.
608KEB
I'll check it and report my findings
608KEB
Could someone post a picture  as to where the ACR is located on this motor? I did not find it in the manual.
Edited by 608KEB
Anglo Traction
Hi, I confess to know virtually zero about this engine, but to offer some clarity.
I believe your engine is as per the Service Manual link provided by Garry earlier, i.e CH12.5.   ACR System is described in Section 10 page 1 (page 89 of the Manual).
As your engine operates with Hydraulic Valve Lift using full Oil pressure, I would suspect the possible cause lies with intermittent sticking Valve Lifters (or Oil pressure) on start up, or the ACR lifting pin is faulty.
For an engine to build up such pressure in the cylinder and to have to undo the Spark Plug to relieve it, neither valve is lifting when it should, but at least you must have good seals on piston rings and  valve seats to store the pressure.
I'm sure there are members here with experience of this model and will point you in the right direction to resolve it.
Regards
Edited by Anglo Traction
608KEB
Regards
Thank you, I read through it. Am I going to have to take the engine apart to fix this? The manual says the ACR is on the cam shaft?
  • Similar Content
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Wvtroutbum81
      By Wvtroutbum81
      Got my dads 1992 312-8 when he passed
      have a snow plow and 42” deck.
      gathering parts to restore back to new as possible. This is my therapy.
    • Tj_WH_Collector
      By Tj_WH_Collector
      Hello y'all,
      I hope everyone is staying safe and staying healthy. If not, i pray that you or whoever is afflicted be healed soon.
      I hope to learn a lot from the forums and hopefully can use some of you young whipper snappers for your brains (ideas, how to's and such). Lol. Btw i am only 30, much respect for the older generation(s)!
      For me, well... If i would have found this 5-6 years ago, i would have said I am new to Wheel Horse. That is about the time my dad bought the 312-8 (that i now own). That purchase and talking to my dad about implements/attachments that i could purchase is what got me so interested in wheel horse.
      Like i mentioned, i started with a 312-8. When i purchased from my dad, it came with a mower pan and a snowblower (wrong model tho). Wisconsin winters were brutal and a regular snowblower was taking me 2+ hours to clear the driveway. Thats when i bought my B-100, included in that deal was a mower pan and a plow. Boy... that B-100 has plowed a lot of snow. I love it.
      I had also bought 2 lack luster tillers at some auctions. Well, that made me look for a tiller attachment. Found one relatively close and went to go look. $200 later, i had a tiller loaded into my truck and i had asked if he had the tillers mount for the rear axle. He said he wasnt sure, but he has a wheel horse sitting in the back. Told me to go look.
      I look over this 854, and there is no rear mount. Just as im getting up, he asks if i want the tractor. I said i only got the $200 i gave you. He said free of charge. And thats how i gained my 854. (854s hood is in my shop)
      I want to start restoring my wheel horses, pretty paint, new decals, clean them up. I am proud of what i own.
      And now im looking at getting a D200 with FEL and a backhoe. Its a sketch time to buy but i could use the tractor for house and cabin work.
      Pics are attached. Please ignore the messes. They aint the prettiest tractors, but they all run.
    • Burnerman
      By Burnerman
      Been a long time since I posted. Hope everyone is doing well.
      I work doing HVAC In a medical center and have been working quite a bit.
      Anyway my son and I made a run to the local salvage yard today to cleanup all the scrap steel that’s been laying around. My wife was happy to see us finally getting some money for our junk instead of paying to get rid of it. Well..... it cost us $20 but we got another horse.
      let’s see how this goes.
      312-8 with SD deck.
