stevebo
1984 C195 & 416-8 Restoration
stevebo
11 minutes ago, 19richie66 said:
Steve, that looks fantastic!
Thanks Richie. Coming out pretty good for a worker restore.
stevebo
  • Excellent 6
stevebo
Fender pan ready for paint then install decals, paint front wheels, wheel weights and install new tires. Oh and paint a few of the rear pto parts and shenis done
  • Excellent 6
PeacemakerJack
Looking great Steve:greetings-clappingyellow:making me want to get going on mine sooner!!!!
19richie66
Looks fantastic Steve! Let’s get moving @PeacemakerJack :teasing-poke:
Edited by 19richie66
  • Haha 3
Tractor boy
@stevebo when your done can I ship you my wheelhorse to restore? Jk 😀😀 -Tractorboy
Edited by Tractor boy
  • Haha 1
stevebo
  • Excellent 4
19richie66
Sure is pretty!
dells68
I'd hate to get it dirty after all of that work!  Very nice!
  • Haha 1
JPWH
Very nice job Steve. Looks too good to work.
Sarge
I'm about ready to sell my pickup truck and go find one of those 195's, man - I love that model.
Sarge
  • Haha 1
Pullstart
On 6/28/2018 at 6:10 PM, stevebo said:
More progress today. I found a local auto paint store sells ready mixed auto paint and it is a really good match (at least the chip was).
Here it’s not even 4 o clock and I’m outta likes for the day again.  That pic of the pile of parts with the Chevy is something else Steve!
  • Haha 1
Pullstart
My grandpa always said instead of mowing the lawn, he was gonna pour cement and paint it green.  I vote Brennan Bo paint it that shiney red!  Looks awesome fellas... -Pullstart
Edited by pullstart
Auto correct...
  • Haha 1
stevebo
Getting close. Need to swap from tires, repaint front rims and install front wheel weights. Some other touch ups with paint (details) and call it done👍
  • Excellent 6
rjg854
Sharp looking tractor,  Steve.  I bet you'll be happy working that bad boy ;)
Sarge
Is it just me, or is that an odd placement for the sway chains on the 3pt?
That's really turning out sharp - very nice work.
Sarge
stevebo
Sarge
I think because the chains are a few few kinks too long it give the look they are out of place but that is the correct location👍
Sarge
Ah, I see now. At first glance, it appeared the chains were on a high, fixed location. I see now they are attached to the top of the main lift arms, which allows them to keep a constant length through the lift range. The D's don't work that way - I've considered changing my 180 over somehow to the same idea so the chains won't bind when you lower the 3pt.
Sarge
stevebo
Sarge a little better angle
Sarge
Yeah - those move on the same arc as the lift arms, much better than being anchored to the mounting frame on the D which is a fixed point.
Sarge
Sarge
Btw - is there any difference in that C series front axle as to strength versus the standard ones? If I can ever find a 195, it would be useful to know ahead of time.
Sarge
stevebo
Sarge
Not sure on the axle but the spindles are larger and have the gussett (spelling)?  I believe they were called the HD spindle upgrade.
Sarge
I'll have to check by the part numbers. I was aware of the HD spindles due to the added weight of that specific C series, but not sure on the axle casting itself. My whole drive is a preference for separate mid/rear lift controls but the D series has far too many weak areas. Sort of a shame they used the angle iron frame in the Super C - the D's frame design was much stronger.
Sarge
stevebo
Sarge,
I did not measure the thickness of the spindles but I would guess at least 1" maybe 1 1/8? That would make the axle different I assume as well. I has a D and pre 76 they all had broken bull gear bolts since they were not hardened and that disaster of a parking "pawl" was a nightmare. Also the tranny shaft always wears as they used the fine teeth.
