Tuneup 1,433 #26 Posted October 3, 2018 Funny that a plug would not fire in that low compression engine. I'm fairly biased on plug brand and heat range as a result of owning an older Japanese air/oil cooled motorcycle (99 1200 Bandit). Careful choice made all the difference. I guess plug choice is always a first consideration and a cheap way to resolve for one variable. Glad for you! Share this post Link to post Share on other sites
pfrederi 18,314 #27 Posted October 3, 2018 I will not use Champions after having the same issue a few years ago Share this post Link to post Share on other sites
ebinmaine 70,603 #28 Posted October 3, 2018 25 minutes ago, pfrederi said: I will not use Champions after having the same issue a few years ago I've been using champions in my small engines for a couple years now but they don't seem to last very long. 20 years ago I was a non wavering fan of AC Delco plugs. Don't know if they do anything small engine. What do you use? Share this post Link to post Share on other sites
Oliver138 7 #29 Posted October 3, 2018 8 minutes ago, ebinmaine said: I've been using champions in my small engines for a couple years now but they don't seem to last very long. 20 years ago I was a non wavering fan of AC Delco plugs. Don't know if they do anything small engine. What do you use? Well I got the tractor last year and it had an Autolite plug in it. While trouble shooting in June, I replaced it with an AC Delco plug. Since the plug turned out not to be the issue in June, I actually put the 'original' Autolite plug back in yesterday to replace the new AC Delco. I would like to get a back-up plug to have laying around now, but am not sure what to get. I can't think of anything off the top of my head, but could there have been something else going on that would have ruined the new plug? Share this post Link to post Share on other sites
ebinmaine 70,603 #30 Posted October 3, 2018 I'm only taking an educated guess here. Maybe a weak coil not throwing enough voltage?. I'm not sure what would cause premature spark plug failure other than a bad spark plug itself. Share this post Link to post Share on other sites
Oliver138 7 #31 Posted October 3, 2018 I felt the same way, @ebinmaine. It's possible the coil isn't giving the proper voltage, but I almost doubt it. Regardless, when I get to re-wiring I plan to replace the coil. Share this post Link to post Share on other sites
ebinmaine 70,603 #32 Posted October 3, 2018 Just now, Oliver138 said: I felt the same way, @ebinmaine. It's possible the coil isn't giving the proper voltage, but I almost doubt it. Regardless, when I get to re-wiring I plan to replace the coil. if you already have one laying around that's one thing but if you have to spend the money on a new coil it would probably be wise to try to test that one somehow first. 1 Share this post Link to post Share on other sites
boovuc 1,090 #33 Posted October 23, 2018 My 2 cents on Kohler points/condenser engines is...........change the condenser out. (Cheap). You may want to look at the points too. I've had some old sets heat up after awhile and give me all kinds of issues but the condenser, depending on ambient temps can do some really funky stuff. Great one day and shutting it down the next. 1 Share this post Link to post Share on other sites
Oliver138 7 #34 Posted October 24, 2018 Thanks, boovuc - where can I get a new condenser? I'm not all the familiar with them, so are they relatively universal or are they engine specific? If I continue to have problems, that will be the next thing I look into. Share this post Link to post Share on other sites
ebinmaine 70,603 #35 Posted October 24, 2018 4 minutes ago, Oliver138 said: where can I get a new condenser PM sent Share this post Link to post Share on other sites
Mike'sHorseBarn 3,115 #36 Posted October 24, 2018 4 minutes ago, Oliver138 said: where can I get a new condenser? A condenser for any K series engine will work. You can get them on the internet or some auto parts stores have them. If you have a napa nearby I know they can get them for you. Mike Share this post Link to post Share on other sites
Phan 17 #37 Posted December 26, 2024 Hi Oliver138 I have learned a valuable lesson from your C160 Auto. Before Christmas, mine only ran for 5 seconds and then died, then nothing happened. I tried following some suggestion from the red square but not I have no any lucks yet. I will check the amp connections - tomorrow. I am curious about how you checked your amp connections. Thank you! Share this post Link to post Share on other sites
