BHunter
New horse in my stable
BHunter
3 hours ago, stevebo said:
I would wet sand with 180 then 320 then maybe 1000 or 1200 then compound and buff.
Thanks for the advise. I’ll try it.
BHunter
The covers are getting a vinegar bath. It’s taking the rust off.
WHNJ701
so you know the vinagar trick! I swear by it.  I swear by it an nobody believes me.  these rims were of a david bradley suburban, soaked a week and steel wool and washed just as good as blasting.
great job with the tractor by the way!
BHunter
Thank you. I believe you. It works and it’s cheaper than the rust removing liquids on the market.Your wheels look great. My boys started taking the Suburban apart today. I had to take the steering wheel off, that was a pain. Tomorrow the hood and deck will come off.
DennisThornton
That is really a BIG jump in grits!  I'd use nothing coarser than 600 if you intend to then buff it!
stevebo
When you are wet sanding that much rust 180/220 is fine and then up it to finer as you go. Just need to wet sand lightly.
AMC RULES
...or, a red Scotch Brite will do the trick too.
Image result for red scotch brite
BHunter
Got up early to beat the high heat in Philly today. The plan for today is to pull the motor and pressure wash.
stevebo
Careful pressure washing ... dont want to take the paint off.
BHunter
Thanks . Very true! I want to save as much as possible. We have an electric pressure washer that doesn’t have too much pressure.
BHunter
Steve, are these the correct foot rests on this tractor? A lot of the ones I see look like they have a notch in them for a boot heal .
Racinbob
That's a good question. Yours are different that the ones that came on my 400 but I really don't know what's original :scratchead:5b379bc560939_Suburbanleft092815.JPG.3e7a148f3b5c0c27a66d354ce40d3e22.JPG
stevebo
I believe they are non wheel horse but look fine to me.
BHunter
Thanks. The patina on them match the rest of the tractor. They must be pretty old.
BHunter
Nice 400 @Racinbob
Racinbob
Thank you. The finished product is the one on the metal Suburban signs Terry sells. I'm curious what the others say about the foot rests. It wouldn't surprise me one bit if both are correct. I picked yo a pair of the cast 61 foot rests at the big show and will get them installed as soon as I get the broken bolt out of one of them and some paint splashed on. Those diamond plate rests now belong to @WHX20 :)
Racinbob
I just went through the picture gallery and it looks like mine Jims were the original. I'm with Steve though, yours look fine. :)
BHunter
Thank you
BHunter
Put a couple of hours in it today and achieved my goal.
BHunter
BHunter
It’s all cleaned up and ready to start reviving the patina
  • Excellent 2
WHNJ701
looking good, get some of that Johnson paste wax, as I said before I followed AMC rules steps on that 701
BHunter
I will. Thanks
DennisThornton
Been a big fan of Scotch-Brite for decades for cleaning and scuffing but it does not level and remove high spots like sandpaper.
WHNJ701
this would look sharp on it!
