RJ Hamner
75 C-160H The Fun Begins Now!
ebinmaine
Sweeeet
I'll be following along to see how this one goes. After my honey's 657 is done we're Switching gears to my c-160 - 8.
oliver2-44
Great Tractor, I have a 74 like it, but mines doesn't purr consistently yet.  Mine has some worn governor linkage and I'm waiting on one more part to replace it.
RJ Hamner
Pulled the battery and was able to get the wiring harness out (after I labeled all the connections) in one piece.
Should be able to make a brand new one when the time comes.
Hood, fenders, running boards, PTO, belt guards all pulled.
Today was TOO hot to mow (96 deg) and the finish on the moulding for the room downstairs needed to cure for another day so.....
Today was bath day.  Soaked everything down with Oil Eater (great stuff).  Let it soak for a while then attacked it with the power washer.
Forty years of grim gone in 30 minutes.:D
  • Excellent 6
Tractor boy
:popcorn:
RJ Hamner
Got it all stripped down to the frame.
Removed the frame from the tranny/hydro.
Stripped the frame down to bare metal with the sidewheel grinder with 80 grit flap sander and a needle gun.
Couple of coats or itching primer and decided to do something different and went with gloss black.
Thought it came out pretty good
  • Like 7
  • Excellent 2
Pullstart
Hey a little mix or black with the red is good in my book!
  • Like 4
Tractor boy
It’s looking good!
Chris G
The black frame and transaxle looks good to me as well.
  • Excellent 2
RandyLittrell
Next Horse on my list to do is gonna have a black tranny, frame and front axle!
Randy
RJ Hamner
While I was waiting on the axle seals got busy with the blast cabinet and sander.
  • Like 7
RJ Hamner
Found some time to get a little work done. This tractor had the soft spongy steering wheel. I had a 74 C-120 that had the same steering wheel couldn't get either one off even with a press.  One gave its life so I could get the shaft. The other made me really mad. I think it's going to be a "yard ornament"  I really like the hard plastic type anyway so guess I will have to find one.  A-Z maybe?
  • Excellent 4
ebinmaine
Absolutely. Lincoln can probably help you out. If not, post an ad in the wanted section.
Your 160 is looking wonderful.
Keep up the good work.
The Tuul Crib
Just a little bit of jealousy here!
Excellent work !!!
cleat
Looking great !
Nothing like a nicely cleaned up machine.
Cleat
RJ Hamner
It's been kind of hit and miss getting time to work on it but...... I did find a steering wheel for richmandred1that cleaned up really nice.
Broke down the engine so I could send it out to the machine shop.
The hobbs meter on it said 1823.7 but I found out it was broken so not sure how much time it has on the engine.
It had a STD piston and like I said earlier it ran real nice without any smoke!?!
The blast cabinet has been getting a workout.  Lots of little parts and a couple of bigger ones.
And a new set of drag links:rolleyes:
  • Excellent 3
Pullstart
I like your cabinet deco!  Tons of fun shooting black powder!  I haven’t found my cleaning kit since our move last year, so the muzzle loader hasn’t seen any action.
PeacemakerJack
:text-yeahthat: I also spotted your SASS sticker.  I have shot CAS for the last decade plus!  Another fun hobby to be involved with for sure.
Great job on your restore, can’t wait to see the finished project:popcorn:
RJ Hamner
Sent the engine to the machine shop and had some free time.
Started on the hood and running boards..
Took then down to bare metal, self etching primer and Regal Red.
They were looking real good and then I was looking at the panel on the right side that hides the belt (aaarggg)
Took it back down and put a skim coat of some 3M body putty and repainted
Looks real good now
Started on the seat pan.
  • Excellent 5
RJ Hamner
After spending a month in St. Louis working on our "other" house then coming back and playing "catch-up" with all the "get ready for winter" stuff I got to spend some time in the shop.
Got the engine back from the machine shop (they do great work but expensive) and I started putting it back together.
  • Excellent 4
RJ Hamner
Got a couple more days without any "honey-do's" so I got to spend some time working on the tractor.:D
I've always said the trying to get all the parts together for a rebuild was like a "scavenger hunt" which at times can be a challenge.:)
But trying to remember where I put those parts can be an even more frustrating challenge because they have to be somewhere within the 24' x 24' space that is my workshop.:eusa-think:
Then again I am the kind of guy that can lay a tool down, take two steps away from it and spend 20 minutes trying to find where I put it.  AAAAARRRRGGGG!!!!:laughing-rofl:
  • Excellent 5
  • Haha 1
ebinmaine
Me too......
The C looks excellent !!!
  • Haha 2
Sarge
At my age - starting to consider the use of tethers to control wayward tools. Always seems to be a pile of them when I come into the house in my pockets/bibs/coat that ends up on the desk - waiting for the next trip towards the toolbox, which I always have to do twice to actually remember to get done. I have a worse time with hardware - got enough to stock a local store but still have to make regular trips for the stuff I need that I cannot remember where I put it...lol.
Sarge
Razorback
Beee-u-T-fullll!!!!!
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • CHuls
      By CHuls
      *Estate Sale*
      71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
      Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
      Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
      Not sure what it's all worth together but, make an offer.
    • PMeadows
      By PMeadows
      Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
