John Deere STX38 Lawn Tractor Repair Series. No Crank, No Start
By
MS GENERAL REPAIR, in other brands
Similar Content
By Gravely Horse
I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
By bigbuck
I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
please call George at 517-499-5678 for more info.
By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
By CasualObserver
Owners manual for the Single cylinder snowmobile engines.
12 pages 1.33MB
1970 295 Safari snowmobile model 9-0011 - 1-cylinder
1970 309 Safari snowmobile model 9-0021 - 1-cylinder
1970 309W Safari snowmobile model 9-0061 - 1-cylinder
1970 355 Safari snowmobile model 9-0031 - 1-cylinder
1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
By Joe Warren
I have a Kohler 301K engine with a Carter carburetor. The engine has always performed very well, but recently has been stalling out after running only a short time. I initially thought it was being starved for fuel. I cleaned and rebuilt the carburetor, replaced fuel filter, and replaced the fuel tank which had some corrosion. I even replaced the Carter carburetor with a new Walbro but I am still having the same issue. I am now suspecting the problem is electrical. What is the likely culprit? Coil? Condenser? Spark plug? Points?
Other?
Appreciate your input,
Joe
