Hobby10k 2 #1 Posted June 24, 2018 Just trying to get to the bottom of what’s going on. Have a 520xi. While going forward, once I start turning the hydrostatic drive starts surging. It doesn’t do this while backing and turning, only going forward and turning. Any ideas? Thanks in advance Share this post Link to post Share on other sites
wallfish 17,082 #2 Posted June 24, 2018 4 hours ago, Hobby10k said: Any ideas? Just a guess since I'm unfamiliar with the 520xi but it seems there could be an issue at the rear axle hub(s). If one or both hubs are slipping on the key then the differential will grab and slip the axle in the hub which would give that condition. 1 Share this post Link to post Share on other sites
squonk 41,360 #3 Posted June 24, 2018 Does this machine have power steering? Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #4 Posted June 24, 2018 1 hour ago, squonk said: Does this machine have power steering? 518 and 520xi does not have power steering only 520Lxi(Kawasaki liquid cooled) 522xi and 523Dxi models, but the 520xi does have the "smart steer" feature because of having "cruise control" which seems to cause issues such as @Hobby10k is having, much like what @wallfish has described with the hubs/keys, Jeff. 1 Share this post Link to post Share on other sites
Hobby10k 2 #5 Posted June 24, 2018 No it doesn’t have power steering like what hillbilly said. So I’m assuming the “smart steer” explains the rod connected to the steering components that goes to the rear of the machine. I Couldn’t really figure out what that was for since it wasn’t doing anything. Does it or even need this smart steer rod on the machine? Can I just remove it? So hub hub key would be right on the axle between the axle and hub? Would be nice if that’s all it was Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #6 Posted June 24, 2018 7 minutes ago, Hobby10k said: No it doesn’t have power steering like what hillbilly said. So I’m assuming the “smart steer” explains the rod connected to the steering components that goes to the rear of the machine. I Couldn’t really figure out what that was for since it wasn’t doing anything. Does it or even need this smart steer rod on the machine? Can I just remove it? So hub hub key would be right on the axle between the axle and hub? Would be nice if that’s all it was The "smart steer" feature works in conjunction with the the "cruise control" to slow the tractor down from set speed on straight line mowing at you turn in the corners so it doesn't flip the operator out of the seat, yes you can disconnect the linkage but wouldn't use the cruise control feature afterwards either, some where in another thread here on RedSquare someone else removed their smart steer feature, Jeff. Share this post Link to post Share on other sites
squonk 41,360 #7 Posted June 24, 2018 i was curious how smart steer works. Share this post Link to post Share on other sites
shallowwatersailor 3,213 #8 Posted June 24, 2018 1 hour ago, squonk said: i was curious how smart steer works. It not only slows the tractor when turning - but lowers accident liability. 1 Share this post Link to post Share on other sites
Hobby10k 2 #9 Posted June 24, 2018 I’m willing to bet if I remove that arm that the surging while turning will be cured. I’m going to do that and update if it fixes it. 2 Share this post Link to post Share on other sites
WNYPCRepair 1,922 #10 Posted June 24, 2018 1 hour ago, Hobby10k said: I’m willing to bet if I remove that arm that the surging while turning will be cured. I’m going to do that and update if it fixes it. Careful, I found this: http://www.mytractorforum.com/13-toro-wheelhorse-forum/309857-5xi-smart-turn-bypass-kit-why.html 1 1 Share this post Link to post Share on other sites
shallowwatersailor 3,213 #11 Posted June 24, 2018 (edited) I doubt that this would affect the engine surging. By describing it as surging, do you mean cutting in and out? You may have a bad seat switch. Here is the instructions and parts drawings for the delete kit. 3324-844.pdf Edited June 25, 2018 by shallowwatersailor 1 Share this post Link to post Share on other sites
Hobby10k 2 #12 Posted June 25, 2018 (edited) No it’s not engine surging, the hydrostatic drive itself surges, slows down and then speeds up quickly (only when turning while going forward) thanks for the diagram shallowwater Edited June 25, 2018 by Hobby10k Share this post Link to post Share on other sites
WVHillbilly520H 10,374 #13 Posted June 25, 2018 3 minutes ago, Hobby10k said: No it’s not engine surging, the hydrostatic drive itself surges, slows down and then speeds up quickly (only when turning while going forward) Here's something to check, the 520xi I had briefly the frame to transaxle mounting bolts were ALL loose from dragging a 60" deck over 3+ acres for 1200 hours, after tightening them all up made a huge improvement not to mention pulling the right rear tire and adjusting the "neutral" on the motion control cam for the hydro, Jeff. 2 Share this post Link to post Share on other sites
Hobby10k 2 #14 Posted June 25, 2018 4 hours ago, WNYPCRepair said: That’s good to know!! I wonder if this has anything to do with why the tractor stays slightly in reverse while it’s supposed to be in neutral while sitting Careful, I found this: http://www.mytractorforum.com/13-toro-wheelhorse-forum/309857-5xi-smart-turn-bypass-kit-why.html Share this post Link to post Share on other sites
WNYPCRepair 1,922 #15 Posted June 25, 2018 43 minutes ago, Hobby10k said: You definitely need to remove the right rear tire and adjust the neutral position, as Jeff said. I need to as well, hoping to do it tomorrow. I also ordered a smart turn disable kit 1 Share this post Link to post Share on other sites
Hobby10k 2 #16 Posted June 25, 2018 I’ll order that kit... where did you order it from? Share this post Link to post Share on other sites
WNYPCRepair 1,922 #17 Posted June 25, 2018 10 hours ago, Hobby10k said: I’ll order that kit... where did you order it from? Cheapest I found https://sleequipment.com/toro-genuine-part-smart-turn-disable-kit-private-label-riders-104-5051.html#product_tabs_advancedreviews_product_additional_data 1 Share this post Link to post Share on other sites
Kurt-NEPA 755 #18 Posted June 25, 2018 I have both a 520xi and 522xi. The smart steering on my 520xi works just fine, but 522xi was driving me nuts. When I made a turn the tractor would almost stop and then as I slowly came out of the turn it would speed up again. It was just slowing the tractor way too much. I tried every adjustment on the linkage, followed the manual, but could not get the smart steer where I wanted it. One adjustment would not get to where the manual said it should be. So I disconnected the linkage from the steering up front and to to hydro linkage on the Eaton 1100. Then I pinned the the open linkage arm at the rear to the frame. (used a bolt and some fender washers, and some regular washers as spacers). That really helped the tractor. No smart steer, but a big improvement for driving. I don't use cruise control, so that is not an issue. I did purchase the defeat kit, but never did install it. 1 Share this post Link to post Share on other sites
WNYPCRepair 1,922 #19 Posted June 25, 2018 I adjusted neutral, helped a bit. I'll do the kit once it arrives. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,101 #20 Posted June 26, 2018 Click on the picture. 2 files on the smart steer delete kit Share this post Link to post Share on other sites
