Willard
Belt alignment 312-8 with 37" mower deck
Willard
In 1987 I purchased a new Wheel Horse 312-8 with a 37” side discharge mower deck.  Two weeks ago the mower deck belt broke (belt was 5 years old).  After I replaced it, I noticed (for the first time) the belt comes off the inside adjustable “V” idler pulley at an odd angle to the inside groove of the PTO clutch pulley.  I cannot see a way to adjust the alignment of the belt.  Belt life has been good – maybe 4 or 5 years between belt breakages.  Could it have been manufactured like this and run this way all of these years?  With the pulley support cover in place, the misalignment is impossible to see.  I happened to notice it before I installed the cover.  It gets a little better as I remove the slack, but not much.  Any suggestions?  Is this normal?  Full disclosure – I had replaced the PTO clutch about 8 operating hours before this belt broke.
gwest_ca
Is that a 6-sided belt? There should not be a twist between the pto and the idlers for either style of belt.
Garry
Willard
Yes, it is a six sided belt, WH #111178.  I believe I have it installed correctly for a 37" mower and the belt diagram you reference is for the 36", 42" and 48" mowers.  I used a magnifying glass on the instruction manual to verify where the twists are and have done it this way for years.  Also, I have two "V" Idler pulleys, not a "V" and a flat pulley, so I believe the belt should NOT have 2 90 degree twists as shown in the diagram.  However, that does not address my belt alignment issue - my problem is with the angle the belt comes off of the inside adjustable “V” idler pulley to the inside groove of the PTO clutch pulley.
Edited by Willard
gwest_ca
I don't know where you are getting the 36, 42 and 48 belt diagram. Click on the photo above. That is a service bulletin that was issued.
Garry
Willard
Garry- My WH Mower Manual for 300 & 400 Series shows 36, 42 and 48 inch mowers have one V Idler and one Flat Idler and the belt having opposite sides touching the two pulleys.  For my 37 inch mower, the manual shows two V Idlers and the belt having the same side touching each pulley.  My Operating manual does not match the service bulletin.  But maybe the service bulletin corrects the Operating manual.  I will have to experiment with the belt installation.
However, my initial post concerns the belt alignment off the inner V Idler.  Any thoughts?
daveoman1966
The engine PTO belt MUST be on the INNER race of the PTO pulley.  Here is the schematic...
Willard
Dave - thanks for the reply.  The belt is in the inner groove of the engine PTO pulley.
  • Similar Content
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Wvtroutbum81
      By Wvtroutbum81
      Got my dads 1992 312-8 when he passed
      have a snow plow and 42” deck.
      gathering parts to restore back to new as possible. This is my therapy.
    • Tj_WH_Collector
      By Tj_WH_Collector
      Hello y'all,
      I hope everyone is staying safe and staying healthy. If not, i pray that you or whoever is afflicted be healed soon.
      I hope to learn a lot from the forums and hopefully can use some of you young whipper snappers for your brains (ideas, how to's and such). Lol. Btw i am only 30, much respect for the older generation(s)!
      For me, well... If i would have found this 5-6 years ago, i would have said I am new to Wheel Horse. That is about the time my dad bought the 312-8 (that i now own). That purchase and talking to my dad about implements/attachments that i could purchase is what got me so interested in wheel horse.
      Like i mentioned, i started with a 312-8. When i purchased from my dad, it came with a mower pan and a snowblower (wrong model tho). Wisconsin winters were brutal and a regular snowblower was taking me 2+ hours to clear the driveway. Thats when i bought my B-100, included in that deal was a mower pan and a plow. Boy... that B-100 has plowed a lot of snow. I love it.
      I had also bought 2 lack luster tillers at some auctions. Well, that made me look for a tiller attachment. Found one relatively close and went to go look. $200 later, i had a tiller loaded into my truck and i had asked if he had the tillers mount for the rear axle. He said he wasnt sure, but he has a wheel horse sitting in the back. Told me to go look.
      I look over this 854, and there is no rear mount. Just as im getting up, he asks if i want the tractor. I said i only got the $200 i gave you. He said free of charge. And thats how i gained my 854. (854s hood is in my shop)
      I want to start restoring my wheel horses, pretty paint, new decals, clean them up. I am proud of what i own.
      And now im looking at getting a D200 with FEL and a backhoe. Its a sketch time to buy but i could use the tractor for house and cabin work.
      Pics are attached. Please ignore the messes. They aint the prettiest tractors, but they all run.
    • Burnerman
      By Burnerman
      Been a long time since I posted. Hope everyone is doing well.
      I work doing HVAC In a medical center and have been working quite a bit.
      Anyway my son and I made a run to the local salvage yard today to cleanup all the scrap steel that’s been laying around. My wife was happy to see us finally getting some money for our junk instead of paying to get rid of it. Well..... it cost us $20 but we got another horse.
      let’s see how this goes.
      312-8 with SD deck.
