bds1984 1,444 #1 Posted June 17, 2018 Since D's are so foreign to me, are their rear axle hubs 1-1/8" like the majority of other Wheel Horses? The reason I ask is I have the opportunity to get some really nice rear tires, wheels, and wheel hubs I would consider for my C165 for an upcoming project. Share this post Link to post Share on other sites
953 nut 55,838 #2 Posted June 17, 2018 Any 1 1/8" hub will fit the "D: axles. Share this post Link to post Share on other sites
pfrederi 17,887 #3 Posted June 17, 2018 D series hubs are much longer and have different bolt pattern and center hole D on the left Share this post Link to post Share on other sites
953 nut 55,838 #4 Posted June 17, 2018 13 minutes ago, pfrederi said: D on the left Sounded to me like he wants to put some already mounter tires and run them on a temporary basis. Share this post Link to post Share on other sites
bds1984 1,444 #5 Posted June 17, 2018 1 hour ago, 953 nut said: Sounded to me like he wants to put some already mounter tires and run them on a temporary basis. Bingo. But probably permanent. I would like to turn my C165-8 into something size wise of a C195 and eventually add hydraulics, rear pto, ect. 1 Share this post Link to post Share on other sites
pfrederi 17,887 #6 Posted June 17, 2018 The outer D set screw will probably beyond the end of C-165 axle Share this post Link to post Share on other sites
953 nut 55,838 #7 Posted June 18, 2018 1 hour ago, bds1984 said: like to turn my C165-8 into something size wise of a C195 If you want to go bigger with the tires you can stay with the five lug hubs and find some Ford or Mopar rims that have the 4.5" bolt circle. You will want to make some front spindles to lift the front end enough to set level too. Then the running boards will need to be moved forward to clear the bigger tires and the seat/Fender pan will need to be raised up to clear. By the time you add a pump and three point and everything you probably would have come out ahead of the game buying a Super C in the first place. 1 Share this post Link to post Share on other sites
