ebinmaine
Advice wanted on saving and using these tires
ebinmaine
My original thought was to remove and maybe sell these or hang them as shop art but the tread is in great shape and they just look cool.
The printed side which someone has moved to the inside of the tires has quite a fair amount of weather cracking and a couple of soft spots.
The solid non printed side appears to be in very good condition.
They hold air fine.
This tractor will be used like our others to pull trailers of stuff around the acreage.... Possibly as much as 400-600 pounds as a guess.
We can use one of the B or C tractors for the heavier loads.
I'll likely put tubes in if they aren't already there. They'll likely also be fluid filled and low air pressure for extra traction.
So... What else can I do to help the tires as far as strength and structural stability?
The little ones on the left
squonk
Me thinks if you try to dismount them the sidewall may rip. Been there, done that.
ebinmaine
Yeah Mike..... I had that thought too.
I believe they'd be ok on the plain side but the lettered side is not so awesome.
WHNJ701
keep the weight off it when not using it with Jack stands
Sparky
  I don’t think anything will bring the tires back. There is a tire paint product out there but that’s to make a tire look better for show purposes.
  Under a heavy load I wouldn’t be shocked if the sidewalls gave out. I had a set of tires with great tread depth but bad sidewalls and one day I came out and the tube had busted thru the sidewall and looked like a huge tumor.
pfrederi
I have 18 horses and a bunch of extra tires...only one tire was worn down tread wise (a front one)  Numerous side wall failures and many that are in use are tubed because of slow leaks....
ebinmaine
That would definitely help and I love the thought but it wouldn't be practical here. These are machines that get used quite often.
2 hours ago, Sparky said:
  I don’t think anything will bring the tires back.....
I don't know of anything that would do it either. I know there is really no way to repair the sidewall of a tire.
I'm thinking that's what's going to happen here. I'll have to change hers over to a spare set from the b80.
They will certainly make cool wall art though!
WHNJ701
sounds like you answered your question, time to order up 4 ag tread tires and a dozen flowers and your all set
  • Haha 4
ebinmaine
HAHAHAHAHHAHAHAHA!!!!
I've said it before and I'll say it again. I am pretty much the luckiest man alive with the girl that I have.
No need for flowers around here.
We talked about it a bit this morning and she may order up or try to find a set of decent used tires around that size at some point in the next few weeks.
Her tractor, her money, her deal.
:handgestures-thumbupright:
Lee1977
With the way you used your tractors in the woods there is only one way to go "new 4 ply tires",
  • Similar Content
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
    • EB-80/8inPA
      By EB-80/8inPA
      A balmy 54 degrees fahrenheit  here today and there are literally clouds of these things buzzing around.  I thought they’d finally disappeared back in early November (November!).  Is this even normal?
