dclarke
'67 Lawn Ranger for the grandkids
dclarke
1 hour ago, 953 nut said:
:text-coolphotos:
Unless you used hardener I would let it dry a week or longer. The decals can trap solvents under them and cause the paint to lift.
Good advice, Richard and Randy. Thanks!
Shynon
As always top notch, looks great Denny:handgestures-thumbupright:
ebinmaine
2 hours ago, dclarke said:
made a heat shield
I like that idea. Most of my tractors will have stacks. How did you do that?
dclarke
My stack is 3” diameter, I used a piece of 16 ga. (I think) metal cut to about 5” x 12”. Heated it a little with a heat gun then formed it around a 3” plastic pipe coupling that measures 4” O. D. Once I had the shape I wanted I cut it to size and drilled a couple of 1/4” holes in it.  I used a 1/4” coupling nut cut in half then shortened each half a little to get the spacing I wanted and welded the nuts to the stack. I did bolt the nuts to the shield and tack them to the stack while it was on the tractor then removed the stack and welded the nuts.
  • Excellent 5
953 nut
6 hours ago, dclarke said:
This project is done.
Not quite done!      :ychain:                    Don't see any Grand kids riding on it.                                :wwp:
dtallon
That tractor turned out fantastic.  I can't wait to see the next one.
You have inspired me to work some on my Ranger 8-speed project, and I am quickly gaining appreciation for the little modifications you did.  What pulley did you use for the transmission input pulley?  I did some measuring and the 2.5" engine / 4" trans pulley set on the Ranger is approximately the same ratio as the 4" engine / 6.5" trans that the 312-8 I got the transmission from had.  Unfortunately I can't just swap over the trans pulley from the Ranger because it has a 3/4" input shaft and the 8-speed has a 5/8" shaft.
Dave
Edited by dtallon
dclarke
Dave
Dave, the input pulley on this one measures 4 or 4 1/4"" it's kinda hard to measure now and the engine pulley is 2 1/2". This tranny has 1" axles and the pulley came with the tranny, I think this input shaft is 5'8". In the past I have used the Maska 4" pulley pictured below on a 5/8" input shaft, I did have to modify it a little but it worked great. I ground the hub down to fit the length of the shaft and had to drill and tap new set screw holes, which I had to drill on a slight angle. I'll use this pulley on my next Ranger project if I can't find a pulley like the one I have on this Ranger.
Pullstart
Awesome job!
dclarke
Here ya go Richard. He loves it!
  • Excellent 7
ebinmaine
Two clear-cut championship-winning calendar shots right there
prondzy
Wow Denny that looks nice! I have been plugging away at the kids Lawn Ranger and now have a few ideas for the gas tank mount thanks to yours. Did you use the stock Throttle/Choke cables or did you buy longer ones and modify?
dclarke
Mike, I had to get longer cables, here’s how I ran the throttle cable.
Shynon
Looks like one happy camper, Great Job Denny:handgestures-thumbupright:
rmaynard
:bow-yellow: Great job Denny. I only wish I had half the fabricating skill that you have.
prondzy
Ok last question Denny, where did you find those throttle cable clamps.They look like nice ones and i havent found any good ones yet.
dclarke
Mike,  the cable clamp bolted to the engine I found in my Dad’s auto parts store back in the 70s. They sold and serviced push mowers back in the 50s and 60s and it was a leftover part from that. I had a few of them at one time but this is the last one I have. The clamp up by the governor was in my junk drawer too. Not sure where it came from.
  • Haha 1
