dclarke
'67 Lawn Ranger for the grandkids
953 nut
12 minutes ago, dclarke said:
planning on adding a second clutch pedal so the kids can reach it
I have seen a couple at the Big show that use the implement lift lever as a hand clutch. They were spring loaded so if the child lets go of it the tractor will stop. Seems like a good safe way to handle the child driver, if they were to fall off it will stop at once.
  • Excellent 3
dclarke
Interesting. I’d sure like to see pics of that setup.
WHNJ701
Looks like a fun project, similar idea with the hand clutch I had both my kids operating tractors young I redid them each a panzer. (I had to get 2 since they couldn't share) they use a hand drive which is easy for them to use.  plus when they were learning I could walk along side and grab it if needed
ebinmaine
Nice work Den.
:popcorn:
dclarke
Richard, I found a video on youtube of a guy modifying a hand lever and it looks like that might be the way to go,espicially while the boys are so young.  Thanks for the tip!
Shynon
Denny, @Terry M has a great clutch/brake set up and @prondzy has his modified with floorboards, hope they will chime in with pics. By the way looks like a fun rewarding build.
dclarke
I started piecing this thing back together to see what modifications I need to make before paint. I had to modify the R.H.side panel and the tool tray to clear the hi/lo shift lever and the tranny dipstick on the 8 speed.
  • Like 7
dclarke
I've managed to get a little more done this week. I had to shorten and bend the trans hi/lo shift lever to get it where I wanted it, I also added a brace to stiffen it some then cut a slot for it in the tunnel cover. There was some play in the frame where the drive belt idler pulley shaft goes thru it so I reamed the holes out and added bushings to fix that. Then I cut a pair of foot rests from a B series tractor down to fit this Ranger and added a couple of braces to the frame to support them. I've still got a little tweaking to do to them but I'm pretty happy with how they fit. I decided to use a different steering wheel so I need to get the seat mounted and figure out what height I want the steering wheel to be. In the pic it's mounted to the original Ranger steering shaft and I think it might be too low.
  • Like 4
  • Excellent 3
Shynon
Looking good Denny :handgestures-thumbupright:
rmaynard
Nice work Denny.
JPWH
Looks like a good fit! All smiles too.
Shynon
17 minutes ago, dclarke said:
Ryder came over to see how it fits.
How long before it's done grandpa
  • Haha 4
dclarke
I’m hoping before the leaves change. Lol
  • Haha 1
prondzy
Looks good Denny, guess i better get back in the garage to finish mine for the kids too!
  • Like 4
ebinmaine
Oohhh.., I think you'll pull that off alright....
Great progress so far!!
Terry M
Coming along nice , Denny !! :handgestures-thumbupright:
dclarke
I only have one pic of my progress this week. I've got the frame and several small parts painted and I disassembled the tranny in order to blast the cases and have it back together with new seals. I'm hoping to have a rolling frame in the next week or so.
  • Like 6
dclarke
Got a little bit done on a Sunday morning.
  • Excellent 4
Terry M
Those Lug nuts look Nice, Denny..:handgestures-thumbupright:
Wildhorse
Very nice! Love the Rangers!
dtallon
Thanks for sharing Denny.  I will be following your progress.  I have an 8-speed and Kohler I am wanting to put in a Ranger as well.
Dave
dclarke
The last few days I've been painting parts and have been able to get a few of them bolted on. I replaced the brake lining with a new one that I had in stock from our vendor Bob Maynard, had to reconfigure the rod that operates the brake band to get it to work and made a link to connect both pedals. Also got the front wheels on and some of the steering installed. Now it's back to watching paint dry.
  • Excellent 6
